  • Replies 3.6k
Posted Images
I cant believe how you are all so quick to praise Vettel and write off Webber. Have we not seen enough seasons the past 15 years to realise that its 80% car and 20% driver. Finally Webber has a good car and he is doing the job. He has shown plenty of pace in the past in shit cars. Look at Button last year. Button is no better then Webber. But give him a car advantage far above what Webber has had this year for the first half of the season and everyone is quoting the fact that he is WDC.
Vettel has not really show much superior pace over Webber this year. He sure as shit has not shown superior race craft. He is quick, and probably has the talen to win 3-4 of the last 5 rounds...but Webber has shown he is driving as good as he has been the past 3-4 years, but with pace in the car, isnt so desperate with some of his dives and race moves.
COME ON WEBBER! There is a reason why he is leading the WDC and it isnt luck. Just like in years past when Button, Hamo, Hill, Schuey etc all had a car advantage... the car wins the WDC more then the driver!
People who haven't watched the sport for a long time don't realise that being fast over a single lap isn't the be all and end all of a formula 1 drivers talents, NPK 3 times WDC no one considers him fast...
But al those ragging on Vettel, it would not surprise me if he wins 3 or 4 of the remaining GPs. He has the car, and he has the pace...it wouldnt surprise me. In fact Vettel is more likely to win 3 of the remaining GPs then Button is to win one
Going to be interesting, really think this WDC is between Hamilton, Webber, Alonso and Vettel...that is the order I think the WDC will finish....but hope Mark can prove me wrong
It looks like the cheaters wings were cheaters wings after all.
Who will kamikaze on lap 1?
Not sure how you draw that conclusion. Ferrari and RBR were both accused of running flexi-wings. Despite the new tests there was an RBR and a Ferrari ahead of the McLarens, supposedly not using flexi-wings. And Webber is only half a second off Alonso's pole time - so where do you get the idea that the 'cheaters' have lost pace?
The relative lack of pace is where I get it from. The Ferrari's pace has improved and so has McLaren but RBR doesn't appear to have compensated yet.
I don't think it was a cheaters wing, it passed scrutineering all season so as far as I am concerned it was legal but by the same token they have changed it to meet the new test and now they are relatively slower. I am disappointed as I want MW to salvage points.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
    • OK, if it idles at 1000+ with the AAC, its not an idle airflow problem. The cold start valve just gives extra air when the engine is cold, but you have enough air without it to idle at 1000. I think you are back to a fuel problem, sorry. Can you see the fuel pressure staying constant or does it drop as the revs drop to a stall?
