  • Replies 90
well its alll good
i put the flush in and ran the car
the ticking stopped and i took the oil out and replaced the filter and put a additive as well as new oil in it so it will clean out the bore and its fine nw
im so fkn happy its driving fine and like nothing happened
thanks for the posts guys it was informative and funny at times
have a mad xmas
well its alll good
have a mad xmas
What flush did you put in the car? There is nothing you can put in your engine that will melt/disolve porcilain...
If it's stopped ticking... dosn't mean it's fine.
FFS! at very least get a compression test done.
Paying someone to look at it is relativly cheap. Best case- you pay someone a couple hundred bucks get a compression test and to put a scope in and check it out. Worst case- you dive it around till it it destroys the head, bore, piston... then little bits of piston/bore/valve do get into the oil and get sucked through the engine. Total loss.
$200 or $4000 ???
Get the fattest piece of hose you can get through the plug hole and still wiggle around, tape one end of the hose to the most powerfull vacuum cleaner you can find hose , empty the vac before you start so you can see what you've managed to get out , now , shove the taped on hose down the plug hole n start vac'n and wigglin .
  • 4 weeks later...
When I changed my spark plugs the other day I noticed the spark plug from cylinder 6 had some porclin from around the tip broken off.... not sure when this happened but im guessing it happened when i accidently boosted it to 1.6bar a few weeks earlier.... I was in second and saw the needle go past 1.5 n backed off straight away n i think it detonated which in turn caused the plug to break :P
Im guessing the damage has already been done :D
anyone else have this problem?
detonation from overboost wouldnt break a spark plug.. they break either from force, or from excessive heat then force.
in other words you smash them with a tool or something, which is alot easier to do when theyve been baked.
    • Hooley Dooley these things have some history! If i sell them they will need a certificate of providence to prove they have been in the hands of verified RB20 royalty! They have been stored in a plastic tub, away from sunlight and moisture. They are in mint condition. And they will stay that way, as i have sprung the money for a set of shockworks coilovers. I'm just working on getting them in at the moment, after rebushing the rear of the car, and while the subframe was out i welded in the GKtech reinforcement bracing as well.  They will get a workout at Ararat King of The Hill in November. I ran 48s on the short course there a few months ago, and i am hoping with new bushes and shocks in the rear i can launch a bit harder. There was a fair bit of axle tramp when i tried too hard off the line. a few of the corners had dips mid way which also made the car feel a bit unsettled, hopefully this will help there too.
    • Food for thought, the stock oil filter thread is a 3/4-16 UNF, which has an ID of about 10 to 12mm (according to ChatGPT lol). Now compare than to an 10AN, which has an ID of about 14mm (Raceworks is 14.2mm, Speed flow is 14.27mm).
    • Yep, totally get that. However hooking in for Generator back up is only a few hundred bucks for the wiring. You could put a couple of those in (for different circuits explicitly) and run a couple of baby generators. Bonus, you can balance them across different circuits, and now have backups in your backup. I'm looking at buying places that won't even have water etc, and I don't mind the idea of getting off the electric grid either, even with everything you've said. This country already has enough power outages that even the mains grid isn't that reliable anymore. I do agree though on spending a bit more to get better gear, and to add some extra redundancy in to the system too.
    • You can set hard reserves on your battery system, and it can't be discharged past that.
    • That sounds like an excellent idea. But total self-sufficiency means exactly that. You have no-one else to blame when your system faults out and you have no power for a week or two while it gets fixed. You'd have to go the whole hog and get a diesel genny and all the switchover gear, to get you through such times. And, despite the fact that over 20 years, my system has been pretty reliable**, I have seen so many inverter explosions (or less dramatic deaths), panel and roof JB fires, and so on, over that time, to know that the stuff is the same as any other bulk Chinese manufactured stuff. The failure rate is well above zero - both on the equipment and on behalf of the meth addled installation labour force. And then..... warranty and means of redress against the supplier you bought the gear from. Best I can tell is that only a handful of solar companies are still around within 5 years of starting their advertising pitch. They disappear and phoenix like crazy. So, as per 1st paragraph, I suspect the only way to is go balls deep and spend maybe 2-3 times as much as you might think, so that you have every base covered. Plus, know and understand your gear intimately, so you can diagnose problems, sort them out yourself, etc, etc. Plus, probably have to consider upgrading various parts as the years pass, to maintain compatibility with newer stuff, performance and reliability, etc, etc. Whereas, remaining attached to the grid has an ongoing cost that keeps going up even if you use bugger all power from it. But it does provide the fallback in case of the worst case with your own gear. You either pay up front or as you go, I suspect.
