  • Replies 118
Maybe try a set of extractors or even a stock NA exhaust manifold on the exhaust. I'm shure you'll pick up some torque over the abortion that's hanging off the side of your head now. Then throw it on a dyno and try advancing the base timing?
Otherwise take it to another mechanic, get the turbo put back on and sell the car!
Buy a barina.
Lmao Thats pretty creative. Butt ugly though. I say if your on P plates you should be driving a slow car until your on opens. Keep that bad boy in place for giggles. But get it chromed. I honestly dont know what a cop would say when they saw it.
"What is this?"
"Its a Chrome Plated Turbo bypass kit officer"
Luke
lol yeah it probably makes great entertainment for all you car fanatics but i clearly stated that i made a mistake by getting this done, you learn from your mistakes and move on, besides i didnt do this myself so no one can put the lame arse mechanic job on my back im just the lame arse one who paid someone to do it.. and im now reversing the mistake by getting it all put back togethor, thanks SECURITY & JonnoHR31 and everyone else who helped out, ill check it out and post some pics when its all done, by the way i should be able to get the yellow rubber tubing from most car places yeah? like auto barn?
doesnt have to be yellow. any rubber hose that size will do. all auto shops should have it
f**k me sideways, quite a novel idea.
seriously take it to some one that knows what they are doing if you dont know what goes where or what material to use for hosing etc then you should not really be playing with it.
so URAS how do you expect new people to learn things if they keep taking it to an expert, i bought this car as a project im pretty tight with 90% of what goes on under the hood and in the cabin just a little lost with the turbo, whats the point of talking to a bunch of losers who just wonna take the piss out of ya, just confuses me thats all i thought this was a social network for people to express ideas and help others.. if you get off giving people shit on a car website you seriously need to look in the mirror and tell yourself to get a life.
thanks for the people who help out young car minds.
Edited by azzafreddy
Don't take it personally man. The reason this is so funny cause most of us have never seen a turbo blocked off like that before. Most people just put a set of extractors on or something, doing it the way yours is done is definetely thinking outside of the box.
IMO only thing you fucked up with the install was still running the turbo ecu and the retarded timing (turbo motor = lower compression so you could get away with advancing timing a bit). thats the reason why your car is so sluggish. the way it was done was possibly the quickest and easiest way of ripping the turbo out otherwise you would've had to throw in the n/a manifold and the front pipe to suit. then putting it back together would've been the same amount of work and snapping manifold studs isnt fun kids.
all youve got to do is run the oil and water lines and its good to go back to normal. its not rocket science and you could do it yourself.
if you can get a programmable ecu into it and get it to a dyno you'll be fine. you might get a few funny looks from the tuners though. its definitely different.
in NSW the fine for driving a restricted vehicle is something like 7 demerit points.... so bye bye license if you get busted.
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
