Centre console in good condition $30
Manual gear suround with gear boot $20
Glove box door $20
Stereo and climate control dash surround $20
Boss kit $20
Full blinker switch together with horn assembly $80
Lock set including ignition lock with matching doors handles (black) with locks and boot lock and key$250
Full steering column suround with ignition light $50
Drivers side front guard full liner $20
Drivers and passenger side scuff plates $50 a pair
Full interior set of imaculate full velour both front seats, rear seat, and front and rear quarter trims
all for $500
Interior cluster surround for manual car including all switches in very good condition $50
Interior cluster with only 104 xxx km on the clock in very good conditon and all gauges working for $200
Rear window wiper blade arm $40
Boot lid black colour slight damage, can be repaired $80
GTS t Bonnet in silver colour, new paint $180
2x Black front doors with glass, power window mechanism and electric mirror for $250 each
RB20det motor with only 82 xxx km travelled, including turbo, air con compressor, and inlet and sensors etc all for $1000
Manual gearbox $500
Manual cluch solenoid, $80
LSD Diff centre $300
Rear Brake calipers $200 set
PLus more parts. To many to list.
Im located in the Ashfield area (Sydney)
https://www.sau.com.au/forums/topic/300995-skyline-r32-parts/
photos?
do you have a stock RB20 crossover pipe?
Hi sorry mate don't have any pics yet, only got them on me phone. I ccould sms u if u like?
Where abouts are u situated?
il take the centre console as long as the lid is in good condition let me know when i can come have a look
Hi how you going? Yeah its in good condition, the lid looks good but inside is alittle cracked due to elbow leaning from previous owner. Where abouts are u coming from? Im in Ashfield area. we could meet up on the weekend if u like to check it out?
i pm'd you about the centre console on the 22nd and still no reply to it. if its still available let me know
cheers mate.
Oh sorry mate, i got a few messages about that. Yes its still available. When would u like to come and look at it? Im in the Ashfield area?
Mate,
Just seeing if you still have the c-pillar trims, I am also after Dash pad and centre console. If you have these items and are in good condition (Mint, o breaks or mark).
Please let me know ASAP.
Mate,
Hi yeah could u please call me on 0415126075, thanks mate
  • 1 month later...
hey dude, interested in boss kit, also would you sell the dash?? , need passenger side dash vent too, and if you have it the lower lip for the front bar??
cheers mate, kern
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
