Good idea, thanks. Sometimes it starts first go, other times it idles bad and really low for as long as 10 seconds thereabouts (no throttle input) before returning to normal (which means revs up to 2k then back to ~1k). I've replaced the pump and the only odd thing I've noticed which is different to before, is that there's no vapour pressure when I open the cap now like there was before.
" blown compressed air down the rubber & metal lines..." Maybe cleared something here?
  • Replies 40
Posted Images
there's generally two options for losing the hiss off the fuel cap. first is the the fuel cap itself isn't holding pressure anymore, other is that the rubber seal where the pump cradle goes into the tank is worn etc.
Interesting! Since the cap seems ok and I didn't change it. But the rubber seal looked a bit mashed and worn. I might have to try to fast it and get a replacement. Also does anyone know what that red goo is on the cap which screws onto the tank access hole where the line goes in? It never sets hard but is obviously not bothered by fuel fumes at all.
Will be a special grease that doesn't damage the rubber. I screw that ring down really tight - using a blunt screwdriver and a hammer to drive the ring around!
Ah - I was only game to make it tight by hand (as I removed it by hand) - maybe I will be a little more 'persuasive' next time :geek: Yes needs to be a special sealant that won't dissolve from the petrol too, as every sealant I've tried does. And this stuff doesn't set hard, so thought it might be something special. Never mind I'll experiment :P
I suspected the same; I ran it in a clear container and checked it outside for signs of sand etc. but I couldn't find anything... just made the kero smell real bad :S
Shook lots of petrol out of it for a few minutes beforehand though; seemed the fuel was trapped in there. I'm not sure about this pump; for ~$200 I'm not about to chuck it, and since it seems to be running fine and I've had a couple of tunes on it... maybe I'll just put it away as a spare.
Edited by DaveB
can fuel pumps hydrolock? be a pretty poor design if they could i guess...
lol, maybe whatever was in there dissolved in the kero, but wouldn't dissolve in the petrol?
Edited by pyro-ns
In my R30s, the S13 and the Stag, when you turn the key on you can hear the buzz of the fuel pump priming the system.
All these are stock. Only trouble I ever had was with one of the R30s. It stopped pumping. Hah! the pump is stuffed. Got
one that was working, put it in but no go. Turned out to be a bad earth connection.( after 24 years!)
I think there is so much electrical stuff on modern, post 1983, that many earth links are necessary to get everything to work. There are even earthing kits you can "BUY".
The other thing that comes to mind is if the priming noise, buzzing, does not stop, then it could be the fuel PRV is farked.
Time to directly wire your new one before that flogs out! They like full 13+ volts.
Well all that has really been holding me back from doing this is the two-stage pump control. ie. it seems that under low-load conditions like partial throttle or idle, the pump is run with a dropping resistor to lower the voltage, make it quieter etc. I want to keep this function if at all possible because I've heard what the pump sounds like at full-bore at idle and I think it would be audible in the cabin.
After looking at the ECU pinout it appears that this two-stage control is taken care of on the ground side of the pump connection, so hopefully it is possible to give it a direct 12V feed at the right place, and still have the FPCM ("fuel pressure control module"???) which controls switching the dropping resistor in and out, regulate the pump's duty as before.
Here is what I plan to do... the original pump-related part of the ECU circuit:
I plan to splice in an extra relay to switch my 8ga direct battery connection (fused separately) like so:
Unfortunately I don't think that I'm going to be able to easily access the connection I want on the pump (near connection 2) and I think instead it's going to be right at the pump itself, leaving the FPCM connected to the original relay output. Hopefully this is only a power connection and nothing more and hopefully FPCM==Fuel Pressure Control Module and it therefore hopefully has another connection (like fuel pressure) and thus the connection near 2 is just for power... if that is the case, it won't care about the pump not being connected there anymore.
Otherwise it might sense voltage drop or something, and having a pretty much constant load with my new connection (original relay just switching coil on new relay) may fool it to running in its "idle mode" all the time... but I doubt it. Fingers crossed.
After seeing how difficult it is to get these pumps going on the test bench, I wonder if this may well make it easier to start... fingers crossed :blush:
My intank Walbro is directly wired for full voltage at all times and the relay is switched on/off only. The only time I hear the pump is when I first turn the key and hear it priming. I am not aware of it when the car is at the lights or otherwise idling. Maybe if you listen very carefully you could pick it out but I honestly don't think it will be annoying. The alternatives, short pump life or engine destroyed by insufficient fuelling, seem infinitely worse. For my purposes - big horsepower and track days - I am getting the extra insurance of a surge tank and a second pump (Bosch 044).
Thanks Bob
Sounds like yours is still running in dual-stage mode, cool. This idea might work then. Another possibility is to connect about a 5 ohm / 10 watt resistor from the earth connection on the pump to earth, which would have the effect of running the "slow" stage of the pump a little "faster" too.
Edited by DaveB
Thanks for the reminder I should check the earth too. PRV==pressure relief valve?
Thanks Bob
No Dave my pump is on all the time or off. When it is on it runs at full voltage the whole time.
Is your car otherwise going OK now? if you are ready for a tune they should be able to put a meter on your fuel system and see what is happening at high revs and also to ensure that it is not leaning out at full throttle.
Good luck
Bob
    • Haha, i kow right? Could have bought so many cars for the same amount of money (or less) but driving Unicorn gives you at least +1mln to style 😅. Like wise man said "life's to short to drink cheap wine and drive boring cars" 😉
    • Newbie here, proud owner of an Autech 260RS. I'm on the hunt for wiring diagrams specific to the 260RS, particularly S1. I've ran my eyes through R33, R34 Diagrams, there are some similarities, however continue to find incorrect wire colours and pins on connectors in the 33,34 diagrams.   I was hoping someone could point me in the right direction? I'd be happy to pay for the originals in Japanese. I can translate them, at least they would be accurate.   Any help please would be greatly appreciated, never heard an RB26DETT before let alone driven one, and I've got a spaghetti monster of goodness to sort out.   Cheers Benny
    • Hey all  im wondering if you can help me please I have put a rb20 box in my r34 gtt as my auto packed up and a friend had a spare box I know it’s not ideal but it will get me up and running for now. we have done the conversation and everything is working great but my Speedo we got a s13 speed sensor but my Speedo reads double now and I bought a speed converter but still not having any luck.  so I thought I’ll reach out and pick your brains  any help would be appreciated please as I wanna drive my car again
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
