basically im running a R32 with a RB25det (see my garage) it is being a bit of a b*tch to cold start the engine... i have a few posibilities from other peeps and just want a few opinions
1. Ignighter problem ($1200 for a replacement from nissan even with staff discount :ermm: )
2. Sparks(i may have got a bit enthusiastic tapping them to .8mm... will test this tomorrow :P )
3. Fuel pump (unlikely as it runs fine and is aftermarket :D )
4. Starter motor (as far as i can tell its working fine :) )
5. timing/air-fuel mix
any help on this matter would be much apprecaited and maybe rewarded with beer (not through post though)
Edited by Jimmae Viper
https://www.sau.com.au/forums/topic/301430-im-stumped-help/
Assuming you are running a stock rb25 with stock ecu.
Have you done a compression check on the engine?
When i lost partial compression in one cylinder, my car was a farker to cold start. At the time, i thought it ran fine, came on boost fine and still made the ass-end loose at the top of 2nd. But the moment my mechanic heard it, he knew i hurt the engine.
https://www.sau.com.au/forums/topic/301430-im-stumped-help/#findComment-5004613
ok when i say a bitch to cold start i mean not runnning temp (weather doesnt affect it)[it fires but then dies or is really sluggish until it gets going, it also stalls if i igve it too much gas before it warms to running temp]...
i had a compression check done and its fine...
Stock 25 ECU...
ill look for the cold start valve in the morning as i gotta take off the body kit to get under...
as for pin 43 i dont mess with the pins ect so have no idea about that...
anyone know where i can get a diagramm for the engine as i lost mine from my computer (damn missus)
Thanks for the massive amount of response, now who wants to help me do a cut and polish :)
JV
https://www.sau.com.au/forums/topic/301430-im-stumped-help/#findComment-5005374
What spark plugs? And try opening the gaps back out to 1mm, seeing as you are running everything stock. Try starting with the ECU temp sender (2-pin connector) disconnected.
Don't understand how a body kit can get in the way of the inlet plenum.
https://www.sau.com.au/forums/topic/301430-im-stumped-help/#findComment-5005553
How old is your battery?
Perhaps giving the battery a full charge or replacing it with a new or different one laying around.
Im recharging my battery at the moment as it gives my car a sluggish start.
I might be silly thinking about the battery but anything is worth a try if you can be bothered. :wub:
https://www.sau.com.au/forums/topic/301430-im-stumped-help/#findComment-5005854
    • There's plenty of OEM steering arms that are bolted on. Not in the same fashion/orientation as that one, to be sure, but still. Examples of what I'm thinking of would use holes like the ones that have the downward facing studs on the GTR uprights (down the bottom end, under the driveshaft opening, near the lower balljoint) and bolt a steering arm on using only 2 bolts that would be somewhat similarly in shear as these you're complainig about. I reckon old Holdens did that, and I've never seen a broken one of those.
    • Let's be honest, most of the people designing parts like the above, aren't engineers. Sometimes they come from disciplines that gives them more qualitative feel for design than quantitive, however, plenty of them have just picked up a license to Fusion and started making things. And that's the honest part about the majority of these guys making parts like that, they don't have huge R&D teams and heaps of time or experience working out the numbers on it. Shit, most smaller teams that do have real engineers still roll with "yeah, it should be okay, and does the job, let's make them and just see"...   The smaller guys like KiwiCNC, aren't the likes of Bosch etc with proper engineering procedures, and oversights, and sign off. As such, it's why they can produce a product to market a lot quicker, but it always comes back to, question it all.   I'm still not a fan of that bolt on piece. Why not just machine it all in one go? With the right design it's possible. The only reason I can see is if they want different heights/length for the tie rod to bolt to. And if they have the cncs themselves,they can easily offer that exact feature, and just machine it all in one go.
    • The roof is wrapped
    • This is how I last did this when I had a master cylinder fail and introduce air. Bleed before first stage, go oh shit through first stage, bleed at end of first stage, go oh shit through second stage, bleed at end of second stage, go oh shit through third stage, bleed at end of third stage, go oh shit through fourth stage, bleed at lunch, go oh shit through fifth stage, bleed at end of fifth stage, go oh shit through sixth stage....you get the idea. It did come good in the end. My Topdon scan tool can bleed the HY51 and V37, but it doesn't have a consult connector and I don't have an R34 to check that on. I think finding a tool in an Australian workshop other than Nissan that can bleed an R34 will be like rocking horse poo. No way will a generic ODB tool do it.
    • Hmm. Perhaps not the same engineers. The OE Nissan engineers did not forsee a future with spacers pushing the tie rod force application further away from the steering arm and creating that torque. The failures are happening since the advent of those things, and some 30 years after they designed the uprights. So latent casting deficiencies, 30+ yrs of wear and tear, + unexpected usage could quite easily = unforeseen failure. Meanwhile, the engineers who are designing the billet CNC or fabricated uprights are also designing, for the same parts makers, the correction tie rod ends. And they are designing and building these with motorsport (or, at the very least, the meth addled antics of drifters) in mind. So I would hope (in fact, I would expect) that their design work included the offset of that steering force. Doesn't mean that it is not totally valid to ask the question of them, before committing $$.
