Are they plastic or metal brackets. Cams approved or not if there plastic I'll pass,,,but thats just me.
This would be much better
http://www.speedzone.com.au/trader.asp?id=5612
Neil.
haha you left your one mistake a year f**king late.
speaking of mistakes I had an almost brand new jack break on me tonight which dropped the car, in fact both graeme and neil have used the shiney new red thing. never, ever trust a jack alone, always use stands.
Oh shit okay I'm wrong,,,everybodies allowed one mistake a year. 27 bucks is way cheap then,,,question is why.
They are featured in the current catalogue, they are only 20% off so not a huge price drop from normal (yes I am a sca employee).
Neil.
Brackets are steel so that should be fine.
Is that the red alloy thing you brought down to Melb ?? :banana: I never liked that LOL
Edited by Tektrader69
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
