Just about to leave for Tokyo for the first time. Staying until the 6th of Jan in Shinjuku. Just wondering if anything major is happening in this time such as Nismo festival etc or any good car showrooms/factories to see??
Also are there places where you can hire GTR's past and present as im hoping to do a little country driving while im there :P
Ta
https://www.sau.com.au/forums/topic/301803-visiting-japan/
  • 1 month later...
Japan is awesome! I hired an R35 GTR from a place called Premium Rentacar, cant remember exactly where it is but not too far from Shinjuku. highlight of the trip!! cost around $650au for 24 hours including insurance
For real??? I'm thinking of going to Japan later this year, this will be my first trip I will do on my own, always wanted to travel somewhere by myself.
So will no doubt be renting a GTR!!
https://www.sau.com.au/forums/topic/301803-visiting-japan/#findComment-5114460
  • 1 month later...
Do it! It's one of those things that has to be done at least once. Oh and if you're gonna go to Japan try to learn how to say a few things, you'll be suprised how little english people speak over there...
https://www.sau.com.au/forums/topic/301803-visiting-japan/#findComment-5194953
Hi guys,
I'll be in Tokyo between 14th June to 20th June.
Just wondering if there is anything interesting on during this time.
Is it easy to go and visit workshops/race tracks - I'm in it for sight seeing?
My plan is to travel around the city by subway/train
If anyone is up for it we can always meet up for a chat and a beer. :(
https://www.sau.com.au/forums/topic/301803-visiting-japan/#findComment-5213014
Wow - that K-tours thing looks awesome - but 7 days and 6 nights is a little bit too much Osaka for me - As I planned Tokyo specifically - but have not locked in accomodation yet :(
But a side trip to Osaka is very tempting.
I've enquired with k-tours if they can do some sort of 2 or 3 day deal (I do part of the tour instead of the whole lot). I'll await their reply.
https://www.sau.com.au/forums/topic/301803-visiting-japan/#findComment-5215360
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
