Good to see an R33 GTS run 12.3 on wed night with 306rwhp on good rubber.
This car was only a 25/40 bolton turbo, Wolf plugin ECU, intercooler + exhaust.
Can't wait to see ND4SPD run now it has 280hp more than this GTS at only 21psi and soft timing,we have left it soft because we have to race Tango1 on tuesday at the plex and didn't want to upset the commish of police.Then we can put good fuel in and crankit up.580 is the highest power run by a GTR on a Shootout accredited dyno in WA sofar!
https://www.sau.com.au/forums/topic/30182-whales-revenge/
  • Replies 65
Make me a coffee and i'll tell you.
Wait till the 2 Bar runs happen next week but remember that this power was in Shootout so don't be suprised when Ant beats "Higher" powered GTRs.
Wheres the Cams Toddler?
I drove ND4SPD today,F--k the 9000rpm limiter hits very fast in the first 3 gears but my balls gave up after 3rd. Ant wants to tune to 10000 after the Tango1 PR day because the power is still climbing at 9000.Wolf ECUs rock.
https://www.sau.com.au/forums/topic/30182-whales-revenge/#findComment-613402
ND4SPD ran at the plex today.
Ant did one recce run then went out for a big go but the Gearbox spat the dummy.The good news is that the car ran 6/10s faster to 500ft than its low 11s best so a 10 is a walk in the park if we can get a box to do 1 pass but the Dog box has just gone to the top of the list.
https://www.sau.com.au/forums/topic/30182-whales-revenge/#findComment-616695
    • Perfect, I'll get to it this winter then at the same time as I weld on my anti squat kit.
    • Alright so my 32 only has one temperature no matter what degree you set it to. I’ve tried disconnecting the servo motor arm and moving it either direction and got no change. I’ve fixed the leak in my AC and re charged it and with it on and clutch engaged it still blows hot even though the low pressure pipe going to the firewall is ice cold. Both heater core hoses are hot while running as well. Diagnostic code showed 24 for intake air temperature sensor. Anybody got any ideas?
    • I said Garrett style. Not Garrett genuine. And something in the G30 550 range is what you want. Not those pokey little old fashioned T28 sized things. The intake ports in the head are small. There is little benefit in fattening up the runners and leaving ths actual ports small. Just run what you've got. And on the subject of Nistune vs Haltech etc..... You know you can control the transmission with decent standalone ECUs these days, right? No need to keep any of that old Nissan bullshit. Don't get me wrong - I use Nistune on my Neo. But it is a DET, so the number of bodges and workarounds I had to do to make it work in a chassis without ABS, TCS, etc, is quite small compared to the herniated arsehole you will have trying to make it work on a motor that doesn't have some of the things that the turbo ECU wants to see. Just easier to bite the bullet and go aftermarket outright.
    • Hmm. Only when the f**king thing is actually working. Still can't find the leak. And that's with dye being put in the last 3 times!
