  • Replies 418
***violence in some of these*** indicated by a star
ok here's some offtopic videos:
*Ramon Dekker kickboxing highlights: http://www.hkstars.net/thaiboxmagazine/Ram...amon_Dekker.wmv i rikey this one very much
*Cheap shot? KO: http://www.sexcrimesinc.com/ko.wmv
Model jet smash: http://korvideo.free.fr/200408/kangaroojet_crash.wmv
Model b52 smash: http://www.stukastudios.se/b52.htm
Flightlevel350.com real plane crashes: http://www.flightlevel350.com/index.php?ac...l&cat=19&page=1
Kerry rocks :D : http://www.kerryrocks.net/kerry.wmv
Stupid ryan: http://up.cav1.com/ryan.wmv
Car Videos...
luckiest man evaaaar... if you only download 1 vid, get this one :D : http://userweb.suscom.net/~friendlyauction...on/wreckedx.wmv
***persuit: http://www.santoalt.com/101/090304/high_sp...eed_pursuit.wmv this one isn't nice at all... i was wondering why i hadn't seen this footage on any of the police chase shows, before the worst happened.
euro rally smash comp (might be a repost): http://www.gt-turbo.org/media/crash_rallye.wmv
burnout dude: http://69.56.161.148/dans_new_video.wmv
mixed racing (57mb): http://video.frankuhlig.de/vln-06-09-2003-...diumquality.wmv (haven't downloaded it all... so i hope it's ok to post)
that's it for now...
GIS 5 = RX7 :D
i wish they'd use a skyline... rx7 is good though :)
here's the teaser:
http://www.getawayinstockholm.com/trailerh...Stockholm_5.mov
mirror: http://www.djdawn.se/film/Getaway_in_Stockholm_5.mov
GIS:
1 http://ultra.cto.us.edu.pl/pub/Multimedia/...ockholm%201.mpg
2 http://ultra.cto.us.edu.pl/pub/Multimedia/...ockholm%202.mpg
3 http://www.4tuning.ro/filme1/ilegale/Getaw...CD-X-Streem.mpg
4 http://www.4tuning.ro/filme1/ilegale/swe6-gis4a.avi
the above gis 4 is the first cd, which is the actual getaway part. the second cd, which i don't have a link for is the good bit - the extras. the driving gets boring after 10 mins. i think i got the 2nd part on an ftp client, which is down now. if i see a swe6-gis4b.avi i will post it... search for that file name.
i appologise if it has been already posted, but does anyone have "the run" video or possibly a link to it. I tried downloading it P2P but all the ****ers have 56k by the looks of it and the movie is a couple hundred MB's.
Possibly DVDrip would be awesome (i know they're out there somewhere) :)
i think:
you can buy it from nissan somewhere...
you could get it on gtrcentral.com, who had a really slow server and isn't even coming up for me anymore
seen requests for it on a few sites but nothing :( leave your pc on at night downloading at 0.01kb/s :):D... how big is it btw?
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
