As the title suggests I just bought my first skyline and am looking at doing some cost effective mods. I dont want to upgrade the power just yet so anything braking, handling, cooling, reliability related with a budget of around 5 grand
https://www.sau.com.au/forums/topic/301956-first-mods/
well start off with doing the exhaust. yes it's power related but won't do much if you don't increase the boost level.
if it still has the stock suspension (not lowered) then you could do a set of coilovers. that will inprove the handling. depending on how good the roads are around you will determine what type is the best to get. if you don't like a rough ride or the roads are a bit dodgy where you are, go a softer set such as tein super street. some of the drifting coilovers are too stiff for some roads. i put a set in my 180 and round a rough corner, going slower than normal i was bouncing onto the wrong side of the road. pulled them out 2 days later and just bought a set of shocks and lowered springs.
also you could do wheels and tyres if it still has the stock wheels. again, the size you should go depends on the roads where you are. if the roads are shitty then i would stick to 17's. and if the roads are good then you could go 18's. but that is personal preference.
https://www.sau.com.au/forums/topic/301956-first-mods/#findComment-5010393
Why fix what isnt broken yet, enjoy driving it instead of worrying about mods, how can you know the mods you make are better unless you have used the original stuff to its full potential, you might just be making it worse
But i would.
Lower it and rims so it looks :/
exhaust so it sounds :(
some form of boost adjustment, cause its :(
That could close to soak up 5k, depending how thrifty a shopper you are, aside that just just improve things as they get old , when your brakes are shot, get better ones, when your clutch is shot get a better one etc etc, your worrying about cooling, why, is it overheating yet, my cooling system is standard and has never overheated on me...yet...
As for reliability, you will find they are very reliable outta the box, anything you do change is going to make it probably less reliable if anything..the only thing that will keep it reliable is regular servicing.
https://www.sau.com.au/forums/topic/301956-first-mods/#findComment-5010486
for 5g, you should be able to pick up (all secondhand) cvoil overs to lower it, wheels, exhaust, return flow fmic, high flow and a boost T, that will be all the basics covered, from there you have to start spending some decent money on any one area to make it better.
https://www.sau.com.au/forums/topic/301956-first-mods/#findComment-5010494
Hey man, congrats on the new car.
for mods, and a budget of 5g i would take it in for a full service first. As it is getting on in years and kms, your timing belt might need a change; high quality fluids all round, new brake pads and discs etc
handling mods are debatable, if its a street car only, id suggest a strut brace in the engine bay and some shock/spring combo; ie nismo s-tune which is great on the road. I had an r33 many years ago and installed some koni shocks and springs - the thing was sooooo annoying.
power mods i personally would limit to an exhaust and boost controller - set the boost to stock as the exhaust will spike the boost which is not exactly best for the turbo and stock ecu tune.
oh and pop an apexi panel filter in the stock box or a pod with heat shield.
good luck and many years happy skyline ownership
-Johnny
https://www.sau.com.au/forums/topic/301956-first-mods/#findComment-5010691
Is it boosted?? lol
I would upgarde the exhaust 1st, make it breathe easier... no need for CAI right away
Then a major service... engine, gearbox, diff oils, plugs, etc
Then a nice set of DBA rotors and green stuff pads
Then coilovers, sway bars... maybe even renew all your bushes as the car is gettin old and the bushes are most probably close to worn out
https://www.sau.com.au/forums/topic/301956-first-mods/#findComment-5019977
-Johnny
This is the BEST way to start if you are going to Keep the car for a while ...
A Healthy Car Check!
Then Check the Brakes (For safety, No Point having a FAST Car that CANNOT STOP!) :)
Comes the Suspension for a Comfort ride
Sway bars for better Handling
Exhaust to make it sound better (Prefer to be FULL exhaust not cat back)
The ECU Upgrade with Possibly a Boost Controller to start off with ....
Hope this Helps :P
Enjoy your new RIDE ...
Best Regards,
Andrew
https://www.sau.com.au/forums/topic/301956-first-mods/#findComment-5020540
    • I dunno about that as a blanket statement. Pitwork is Nissan's "Nissan genuine" thing, and for stuff like timing belts, I have found them to be excellent. Of course, for things like oil filters, you always use proper trusted brands anyway, not whatever the OEM has taken to using.
    • Ahhhh... If you were putting 12V to the led in there, that's likely made it very unhappy. Chances are how you put power, was 12V across an LED that's meant to only have about 20mA through it at peak, and a forward voltage of about 1.8 to 2.4 volts. That circuit is likely only a 3V3 circuit, and will have a resistor in series with the led too. That's my guesstimate on that light, without having touched one.
    • Another vote for installing them and see how you go.  I mean, you already own them, why would you not fit them?
    • I have had too many of those over the years, my cars have a toolkit or at minimum a cheapy multi tool thing because its too easy to be snookered by some stupid plastic clip that stops you checking the battery terminal isn't loose.
    • Basically, if there is a part# on the nissan catalogue, it is a genuine part. There is a thing called "new old stock" which is stuff made years ago but never sold (or landfilled), but it is super hit and miss what you can buy. Other than some expensive Nismo stuff there is nothing new being made that suits these cars. The only time to be a little careful is (mostly in the US I think, but maybe Japan too), Nissan started rebranding some cheap crap maintenance parts like oil filters as "Pitworks"; stay away from them, if you are buying cheap just buy whatever the local car parts shop carries The three part numbers have an explanation on Amayama: 0V005 is auto, base style 0V015 is manual 0V505 is auto, hectic momo branded ones, maximum F&F points there!
