  • Replies 521
Yep Ballin....It sounds like it....Black in colour....
Be surprised if it was a TRUE GTR.....
Yeah i think....actually im sure i know who ur talkin about. It is a GTS-T not a GTR. He only bought the car recently and it came done-up. Its got a bigger turbo and intercooler and he'z running his boost around 13psi. well juz thought id fill in my share of info :cheers:
https://www.sau.com.au/forums/topic/30197-darwin/page/14/#findComment-1213664
hey. i own the black r33 getting around darwin with all the LA style orange stickers down the side. little about the car it has 18" rims, full bodykit, HKS intercooler and HKS high flow turbo, TRUST internals,mandral bent apexi exhaust system and lots of other little things which will discuss later. still new up here so looking for anybody who wants to meet up? im never on the net anymore so sms me on 0405476624 and let me know where to meet all you skyline fans. peace out! ps. AB if you read this look for some people to cruise with us man.boring jus us two gan!
https://www.sau.com.au/forums/topic/30197-darwin/page/14/#findComment-1230127
  • 1 month later...
hi everybody, im in Kuwait doing some stuff, its blinking hot here and i love the beach and all but there is just way too much sand here.....
anyway the Kuwaity people are cool and hella funny most of the time, and they are experts at dodgem cars and road rage lol ..
anyway i'll keep you all updated
This is CHICKO, reporting to you live from Kuwait, For SAU News (lol)
Cheers
https://www.sau.com.au/forums/topic/30197-darwin/page/14/#findComment-1324131
Have just bought a power FC, boost kit and hand controller. Oil filter relcation kit is still coming.
However I read instructions that said: Power FC doesn't retard timing on detonation.
I'm already getting detonation so bit worried about fitting it without doing soemthing first. Don't want crocked engine/turbos again.
Bloke at work reckons I should put some upper cylinder cleaner through (Subaru have some crap in a bottle).
Anyone used a similar product up here? I'll have some crud in the top becuas eof the blown turbos last year.
Cheers,
John
https://www.sau.com.au/forums/topic/30197-darwin/page/14/#findComment-1342456
What boost are u running? Have a larger FMIC or standard?
Better intercooler from standard and/or running your boost down lower for a bit may do the trick. Premium fuel, good engine oil and some decent runs should get and keep off most of the carbon in the combustion chamber and piston crowns.
https://www.sau.com.au/forums/topic/30197-darwin/page/14/#findComment-1343212
Standard GTR intercooler. Has the N1 slots in the bumper.
Boost is "stock". But the original turbos were very very buggered (huge smoke screen) so I expect grunge might be up top.
Using Ultimate 98 (of course). Due for a service (time not KM)
Noticed that the last tank fill from the BP in town didn't seem to agree with the car (compared to the last few fills from Fannie Bay).
https://www.sau.com.au/forums/topic/30197-darwin/page/14/#findComment-1343230
hey guys whats been goin on its very quiet on these forums i cant talk to much i dont get to the computer too much, we should organise a cruise/meet for mid-end next month, what do ppl think even if its cas beach bbq etc ideas?
Good idea .... I'd be in that. Lets organise it for a Sat or Sun arvo :ddd:
https://www.sau.com.au/forums/topic/30197-darwin/page/14/#findComment-1347462
    • I came here to note that is a zener diode too base on the info there. Based on that, I'd also be suspicious that replacing it, and it's likely to do the same. A lot of use cases will see it used as either voltage protection, or to create a cheap but relatively stable fixed voltage supply. That would mean it has seen more voltage than it should, and has gone into voltage melt down. If there is something else in the circuit dumping out higher than it should voltages, that needs to be found too. It's quite likely they're trying to use the Zener to limit the voltage that is hitting through to the transistor beside it, so what ever goes to the zener is likely a signal, and they're using the transistor in that circuit to amplify it. Especially as it seems they've also got a capacitor across the zener. Looks like there is meant to be something "noisy" to that zener, and what ever it was, had a melt down. Looking at that picture, it also looks like there's some solder joints that really need redoing, and it might be worth having the whole board properly inspected.  Unfortunately, without being able to stick a multimeter on it, and start tracing it all out, I'm pretty much at a loss now to help. I don't even believe I have a climate control board from an R33 around here to pull apart and see if any of the circuit appears similar to give some ideas.
    • Nah - but you won't find anything on dismantling the seats in any such thing anyway.
    • Could be. Could also be that they sit around broken more. To be fair, you almost never see one driving around. I see more R chassis GTRs than the Renault ones.
    • Yeah. Nah. This is why I said My bold for my double emphasis. We're not talking about cars tuned to the edge of det here. We're talking about normal cars. Flame propagation speed and the amount of energy required to ignite the fuel are not significant factors when running at 1500-4000 rpm, and medium to light loads, like nearly every car on the road (except twin cab utes which are driven at 6k and 100% load all the time). There is no shortage of ignition energy available in any petrol engine. If there was, we'd all be in deep shit. The calorific value, on a volume basis, is significantly different, between 98 and 91, and that turns up immediately in consumption numbers. You can see the signal easily if you control for the other variables well enough, and/or collect enough stats. As to not seeing any benefit - we had a couple of EF and EL Falcons in the company fleet back in the late 90s and early 2000s. The EEC IV ECU in those things was particularly good at adding in timing as soon as knock headroom improved, which typically came from putting in some 95 or 98. The responsiveness and power improved noticeably, and the fuel consumption dropped considerably, just from going to 95. Less delta from there to 98 - almost not noticeable, compared to the big differences seen between 91 and 95. Way back in the day, when supermarkets first started selling fuel from their own stations, I did thousands of km in FNQ in a small Toyota. I can't remember if it was a Starlet or an early Yaris. Anyway - the supermarket servos were bringing in cheap fuel from Indonesia, and the other servos were still using locally refined gear. The fuel consumption was typically at least 5%, often as much as 8% worse on the Indo shit, presumably because they had a lot more oxygenated component in the brew, and were probably barely meeting the octane spec. Around the same time or maybe a bit later (like 25 years ago), I could tell the difference between Shell 98 and BP 98, and typically preferred to only use Shell then because the Skyline ran so much better on it. Years later I found the realtionship between them had swapped, as a consequence of yet more refinery closures. So I've only used BP 98 since. Although, I must say that I could not fault the odd tank of United 98 that I've run. It's probably the same stuff. It is also very important to remember that these findings are often dependent on region. With most of the refineries in Oz now dead, there's less variability in local stuff, and he majority of our fuels are not even refined here any more anyway. It probably depends more on which SE Asian refinery is currently cheapest to operate.
    • You don't have an R34 service manual for the body do you? Have found plenty for the engine and drivetrain but nothing else
