  • Replies 521
f**k yea, 104 in a 60 zone :3some: i was gonna go for a run but it was a pusute car so i thought i better not, but the cop was ok, he said he saw me in the 80 zone when clearly was not but i wasnt gonna argue with that... $210, oh well, paid it about 20mins after so its all good
https://www.sau.com.au/forums/topic/30197-darwin/page/22/#findComment-3053823
well found out in the last two days im either comin back up there or too brissy at the end of the year my job prob wont be here at the end of the year, so the sinista plates may grace my car once again, this time i will be back with avengence (hmmmm 320odd rwkw) hahahaha i have to wait to find out lol
https://www.sau.com.au/forums/topic/30197-darwin/page/22/#findComment-3063704
Hey ill be in Darwin from 21st of June to 3rd July.
How about a cruise on the 30th so i can have a look at some Darwin Skylines???
I can participate in the cruise in either a 4wd or Hyundai! (Dont judge me, its not my fault) LOL
https://www.sau.com.au/forums/topic/30197-darwin/page/22/#findComment-3134954
if you want that , you will have to post in the NT section of Boostcrusing.com , as there are not enough skylines to keep this part of this site running , there are some very nice lines up here so I hope it happens
Cheers
Jaqule
https://www.sau.com.au/forums/topic/30197-darwin/page/22/#findComment-3136793
26 the 31 Zac, pron!
I have thought about it but its a bit of work... was guoing to do a 25 because they're not so much work. But looks like i could have another RB30 soon, and it wont cost me jack so i'l probaly do a crazy RB30. :sorcerer:
https://www.sau.com.au/forums/topic/30197-darwin/page/22/#findComment-3153920
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
