  • Replies 521
f**k yea, 104 in a 60 zone :3some: i was gonna go for a run but it was a pusute car so i thought i better not, but the cop was ok, he said he saw me in the 80 zone when clearly was not but i wasnt gonna argue with that... $210, oh well, paid it about 20mins after so its all good
https://www.sau.com.au/forums/topic/30197-darwin/page/22/#findComment-3053823
well found out in the last two days im either comin back up there or too brissy at the end of the year my job prob wont be here at the end of the year, so the sinista plates may grace my car once again, this time i will be back with avengence (hmmmm 320odd rwkw) hahahaha i have to wait to find out lol
https://www.sau.com.au/forums/topic/30197-darwin/page/22/#findComment-3063704
Hey ill be in Darwin from 21st of June to 3rd July.
How about a cruise on the 30th so i can have a look at some Darwin Skylines???
I can participate in the cruise in either a 4wd or Hyundai! (Dont judge me, its not my fault) LOL
https://www.sau.com.au/forums/topic/30197-darwin/page/22/#findComment-3134954
if you want that , you will have to post in the NT section of Boostcrusing.com , as there are not enough skylines to keep this part of this site running , there are some very nice lines up here so I hope it happens
Cheers
Jaqule
https://www.sau.com.au/forums/topic/30197-darwin/page/22/#findComment-3136793
26 the 31 Zac, pron!
I have thought about it but its a bit of work... was guoing to do a 25 because they're not so much work. But looks like i could have another RB30 soon, and it wont cost me jack so i'l probaly do a crazy RB30. :sorcerer:
https://www.sau.com.au/forums/topic/30197-darwin/page/22/#findComment-3153920
    • Despite the level up question, actually I do know what that is....it is a pressure sender wire.  So check out around the oil filter for an oil pressure sender, or maybe fuel pressure near the filter or on the engine. Possibly but less likely coolant pressure sensor because they tend to be combined temp/pressure senders if you have one. Could also be brake pressure (in a brake line somewhere pre ABS) but maybe I'm the only one that has that on a skyline.
    • Pull codes via the self-diagnosis procedure. As far as I can tell this is just a sign of transmission issues but not a code unto itself.
    • Hi All, putting the engine back together and everything is perfect except have this plug left over.. any ideas what it is for and where it goes? Is on cold side under the intake plenum *note not a stock plug, as everything has been modified Cheers
    • Sounds like a misfire. Check fuel pressure and don't even think about going into boost while it's like this unless you enjoy engine rebuilds.
    • Just. Gasping. Here. Just. Gasping.
