Hey guys, i have an embarrasing questions.... Here it is
I brought myself a 1993 Skyline R33 Gts25t and noticed 2 buttons that say spoiler up and spolier down, the spoiler down button is under the spoiler up button they are sitting in the dash just to the left of the steering wheel, when i press the buttons i can hear a, eletrical motor run but i dont notice anything happen, the switches look like they are factory not after market so if anyone could tell me what they are there for i would be thankful
Thanks guys
https://www.sau.com.au/forums/topic/30198-strange-buttons-in-dash/
mind you if you have an aftermarket front bar or a bumber that was repaired after an accident, those switches are as useful as tits on a bull.
If they don't do anything I suggest you rewire your amps remote volume control to those switches... go for that factory look. :D
as far as i have read they were an option on 31's, 32's & early 33's. the buttons on the dash only work when the car is on, stationary & with the handbrake on. otherwise it comes down automatically at around 75km/h & will stay down until u click the up button in or drop below 50km/h.
mine still works & is the only one i've actually seen operate.
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
