  • Replies 99
Just replaced with new dry cell battery. Car runs perfectly, no one seems interested, only 2 people have come to see it in 7 months being for sale.
$17,000. i'm looking at. let me know if your interested so i can come down.
bwhahahahahahahahaa
atleast have the decency to look at the car and how silly your low ball offer sounds :)
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
