  • Replies 99
Glad to see i'm not the only one struggling to sell! Mine's been up for sale a while too, very few calls. I think a lot of buyers must still be choosing to bring them in from Japan rather than buy locally. Decided to keep mine, love it too much to sell for a pittance.
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
