http://www.flickr.com/photos/42559667@N06/4253899054/
Today's photo is of my dirty 18x9.5+35 rear wheel on the ceffy parked up against the garage door. Added some split toning and colour burn to bring out the detail in the dirt and alloy post process.
  • Replies 164
Posted Images
Nice Funkymonkey!
I think the cross processing look brings out the image a lot more. I like it :P
Here's mine for today (yesterday) i think i went a little too overboard, but i still like it.
Ok guy's I need your help I have a eos cannon rebel and I want to get a good pick of my front end moving how close do I have to be and what kind of speed in the car and schutter speed ....I'm new at this .....I dont have a wide angle lence .....I do have hero cam!!!! with wide angle but I can't slow down the shutter speed I don't think
By the sounds of it you mean a rig shot? If so you will need suction cups(Avenger F1000), boom arm(Around 10-15ft pole that has minimum flex), magic arm(Manfrotto) and super clamps(Manfrotto).
Otherwise for panning, shutter speed of between 1-30th - 1/160th (Depending on how much motion blur you want), pan with the car as it drives along and keep panning with it until the shutter has completely closed and taken the photo.
Takes a fair bit of practice but your bound to get a keeper. Best to start with your shutter speed higher and lower it as your keeper rate gets more successful. Normally you don't use WA lenses for this, you use super tele's (70-200/300/400/500/600) because you will be shooting from a distance and want a nice tight framed shot.
Hope i helped.
ah nice one kory. how did you light that? couple of speedlights, gels?
ive got two speedlights now and only just starting to learn how to use them properly. will be a bit of a curve for me, im used to straight up motorsports where flash is actually a no no, lol.
Close Funkymonkey!
I used a Vivitar 285HV with a 1/2 CTO gel and a pure blue Gel to light the background (put right underneath the glass a bit further back and bounced off the background).
And then 2x AB800's (strobes) to light it.
Everything was off camera and triggered by wireless triggers.
It's pretty simple to do, you just need a flash/strobe that has a fast enough flash durating to freeze the liquid. It is basically a light tent that it is in (the glass).
Setup consisted of:
White styrofoam on the sides of the cup and behind the cup (background). The White pretty much acts as reflectors.
1x AB800 on the left with a PLM (big bounce umbrella) with White front Diffuser fabric on which is equivalent to a large softbox.
1X AB800 on the right in a 47" octabox.
Tripod - so you can make a composite and because for this i found it was easier to keep everything straight.
Reason i used modifiers is to soften the light so it is not as specular and hard. I really am a fan of soft light.
I also did a composite with this image. I took one of the background with the glass there. Then turned on the strobes, and got my mate to drop icecubes in from above and then merged them together in photoshop and added layer masks to paint in some drops/splashes and then used the healing brush to blend it all together.
It was shot at 1/125th, ISO 100, F5.6 (i think from memory, unsure if the exif is still there).
AB800's were at 1/32th power.
Hope i have helped and sorry for the super long info! Got a bit carried away :(
Edited by FST513
From what i can see the photos are still looking great
i was just wondering (havent been able to look in shops or find prices online)
BUT
approx how much are shutter release cords? need one for my canon. even though every weekend i tell myself i want to go play with the camera and it NEVER happens.
i like jay019's middle shot and zennons city corner shot.
    • One thing I can tell you is, do it properly the first time. If you encounter unexpected problems just let the car sit for a week or two if you have to get some other parts or figure stuff out.  I'd have said go and use as many OEM parts as possible but since you want to change the turbo later on a custom kit is probably the better choice. Since I have no experience with RB25 just compare parts diagrams and images before buying a line kit and it should be easy to see if it has everything you need. Amayama has very good parts diagrams and part number lists, that is what I used a bunch to figure out what I might need. And don't forget to plan ahead and possibly renew other stuff that's easy to get to while you're in there doing the turbo lines. Happy wrenching
    • Update 4:   Hi all, good news. Engine is running and all the gaskets and seals seem to be working as intended. No leaks so far, even the JB Weld seems to hold. I flushed out the old coolant a few times and put in fresh coolant, not Nissan stuff, I decided to try the Ravenol Protect FL22, they claim it works for a wide variety of JDM cars and the opinions on it by some people were pretty good. And it has the nice poison green color! And man am I glad I bought a coolant system tester earlier this year, vacuum filling works wonders on this engine. I can definitely recommend this to anyone still doing it the old school way. All you need is compressed air supply. Will have to do a small test drive as soon as I can, I removed the gauge cluster again as the tacho needle was still bouncing around a bit but it was much better than before already.  I also found some cracks on all 4 tires inner and outer sidewalls. Apparently these tires should 't be parked on for extended periods or be kept under 0 degrees during storage, which I did not know. Clearly the previous owner didn't look into those details either, he probably bought them just cause they are cool semi-slicks. I'm just wondering how tf I am supposed to reach 30-80 degree tire temperatures on the public road consistenly, these tires were never going to work for my use case. I'll probably order Continental SportContact7 ones as these are the best allround summer tire available right now and I don't think I'll need anything crazier for now. Do let me know if you have experience with various tires and which ones you recommend.
    • You have no idea how many goddamn boxes I received these past three months haha Most have been put to use by now though, luckily
    • Not going to pretend I didn't do a bit of junky work this time around, but mostly due to the fact that some things I am not willing to spend days fixing right now, like wiring. I try to do most things properly the first time around.
    • Regardless of neglect or incompetence, fixing either is tedious and annoying. Most of the neglect on my car is definitely rust. I hope I can at least pass inspections later on and they won't fail the car due to slightly corroded hardlines. I was generous with rust converter and wax and it looks ok, most lines in the rear are hard to see properly anyways.  Definitely will test them though to make sure they don't rupture under pressure, in that case the car isn't going anywhere this year.
