OK, so firstly....when fitting cam shafts into your engine...be sure to tighten the bolts holding the bearing clamp over the cam lobes that are having to push down on the valves first!!!
you do this to avoide snapping the camshaft like i just did! and these were Tomie Camshafts that i just purchased second hand for a very good deal.
this was a very expensive $500 lesson i just learned!
anyway life goes on and i must not let my anger consume me anymore....
so time for more cam shafts! i will be buying these on monday or tuesday and as a result i now have a new choice....
Just Jap are the only place i know that has the Tomie cams instock and they are $1200. i know a place i can get the HKS stage 1 cams for my RB25 for $1500 for the pair.
so given now that there is only a $300 difference...should i get the HKS ones for the Topmie ones???
Points to consider:
i am running a HKS GTRS turbo with Plazmaman Plenum and HPI Ex Manifold and 3" Kaikimoto Exhaust and HKS Dump (power FC for computer and all other normal supporting mods, IC, Inj, AFM, etc)
Car is driving 90% on the street to work everyday. it sees track time approximatly once a month.
https://www.sau.com.au/forums/topic/302215-rb25det-cam-shafts/
what power was the car making with out cams?
i had a similar set up with HKS INLET, Duration 256. Lift 8.8mm,EXHAUST, Duration 264. Lift 9.0mm and they are excellent you can get them deliverd for just under a$1000.
Edited by WARLORD
As an alternative, price up a set from Kelford and Tighe. Neither are likely to retain VCT, so factor in vernier cam gears (if you don't have them already).
The Jap stuff is obviously very good, but remember there are alternatives - provided you're then prepared for an hour on the dyno to dial the cams in.
Bummer about breaking a camshaft though. Hasten slowly, and use your eyes as you go.
So sorry to hear about the incedent.
I chose the HKS cam as they are the largest cam that retain the VCT on the inlet which is exactually the same as warlord's spec's.
This is a choice if you are considering retaining the vct.
other then that go the kelford or camtech.
Ah yes well you see here lies a small thing... I did snap the exhaust cam. But in my fustration and anger for being so stupid I just threw it all out and in doing so dropped the intake cam and damaged it.
looks like a new set then eh.
are you sure Camtech ones are non VCT?
So on to what to order tomorrow morning...
Hks cams or tomei poncams???
or should I try Procams 260 with 8.8mm lift?!? What happens if I don't upgrade to new vale springs?
all depends on seat pressure vs boost level you are planning to use
Edited by DiRTgarage
    • Time will tell, they're doing all the admin stuff at the moment. I've submitted all the required details, photos, etc.   I was under the impression that DC coupling is the best approach, i.e.: Solar Array -> Battery Invertor -> Battery  Where as AC Coupling is simpler, however less efficient, i.e.: Solar Array -> Solar Invertor -> Battery Invertor -> Battery
    • The price is really great for that kind of capacity. I thought similar setups cost way more. How's your efficiency been with the DC-coupling? I've heard sometimes there can be a bit of a performance loss.
    • Long time no random post about shit. So I went down this deep deep rabbit hole of battery storage for the home, ended up locking in a 41.9kWh Fox ESS EQ4800 with 9 units stacked. Battery uses Lithium Iron Phosphate, similar to what you find in those deep cycle boat/caravan batteries. And yes, why did I go with a cheapie brand and not like Synergy? simply because I don't plan to stay at this house for more than another 3~5 years.  The entire install, DC coupling (removal of existing invertor, connecting the current 6.6kW array direct to the battery invertor), new 8kW invertor is $6K all up (after all the rebates etc.). Going with this lot: https://www.aussiesolarbatteries.com.au/ It did seem a bit too good to be true, however seems like the Whirlpool community has vetted it and when it comes to this kind of stuff, they seem to be all over it: https://forums.whirlpool.net.au/thread/9pxj8482?p=38   I've requested for the battery to be installed outside, next to my meter board and not inside - rather have it combust and ignite outside lol.
    • In Vic it would be a defect regardless of whether or not you cut a hole in the sheetmetal for the return pipe. The rules in Vic are shitful, and are generally interpreted as you can "make 2 mods to the intake system". Putting an FFP and an FMI onto it will almost certainly be seen as some huge number of intake mods. You really need to speak to an engineer before doing this stuff in VIC.
    • planning a r34 rb25 de+t with some other work, rather just have it done in a shop due to space limitations any recommendations? I have most the parts already I seen online Moore Performance and DR Drift any advice appreciated thanks
