Up for sale is my 1990 R32 GTR. Since owning this car a great deal of time effort and money has been spent to bring it up to standard and it now represents an outstanding car. It has been built with the intention of being solidly capable of track use however this does not compromise its street ability. Only quality parts have been used and I deeply regret having to sell it however i shall be relocating overseas from March and it must go.
The Good:
Freshly imported RB26DETT w/165-170+psi accross all cylinders
Braided -8 Oil Drain from Head to Sump & speedflow fittings
GTR R33 Rebuilt N1 Turbos w/ < 1000km on them
OBX Stainless 3" Split Dump Pipes
10 Month old Dry cell in the Boot
Trust Oil cooler and Relocation Kit
ARC front mount intercooler
HKS Boost Controller
Greddy Turbo Timer
Rebuilt Gearbox ~ 8000km ago
Exedy Twin Plate Clutch ~ 8000km ago
JJR Cam Gears and Gates Timing Belt < 1000km
New Genuine Nissan water pump < 1000km
New Genuine Nisasn Idler Pullies < 1000km
New Genuine Nissan Drivers Seatbelt
Rebuilt Front Driveshafts < 1000km
ADR Approved Stainless Brake Lines < 50km
New RDA Slotted Rotors all round < 200km
Bendix Ultimate front pads
QFM A1RM rear pads
3.5" HKS Super Dragger Cat Back
New Mid Muffler < 1000km ago
Std R32 wheels ex cond with New Kumho KU31 Rubber < 300km
Adjustable Castor Rods
Koni Coilovers
Cusco 3point Front and Rear Strut Braces
New Tailshaft Bearing < 50km
Polyurethane Diff Mounts < 1000km
Solid Alloy Pineapples in rear Subframe
New Front Steering Tie Rod Ends
New Rear Passenger Inner Tie Rod
New FR upper control arm bushes
Rockford Fosgate Mp3 CD player
No Rips or Tears in the Interior
Remapped ECU by Garage Saraus, checked on the dyno and running a conservative and safe tune at 1bar.
The Bad:
Clearcoat is pealing on passenger door
Soild Alloy Subframe Pineapples transfer a fair amount of NVH
Dash oil pressure gauge is playing up but an aftermarket one is supplied
Bonnet has some very light hail damage.
I have personal records of everything that has been spent recently on this car which in parts total close to $15k not including my time or labour where relevant. Many photos are available of the work done to the car as are the dyno sheets. Compliance paperwork, and regency compliance paperwork is all intact and presentable for the new owner.
Recently made 256RWKW @ 1 Bar on John Keen's Dyno Dynamics Dyno and has been to Mallala 3x times with laptimes consistently around 1.24 running conservative boost and the old brake setup. Will easily be capable of Low or Sub 1.20 with fresh rubber and the right driver.
Also have that may be sold additional to the car:
17x9 5 spoke, 3 piece SSR Evoloutions with Dunlop Semi slicks $1200
Spare RB26DETT (most bits there, low compression though) $1200 Whole
A thousand other bits, clutch, 4x turbos, new adjustable front camber arms and the list goes on.
Serious enquiries only, No Joy riders. Please do not be offended if i ask to view your Drivers license if you are serious and wish to test drive the vehicle.
Contact Robert - 0423128994 or e-mail [email protected]
Edited by WhO
https://www.sau.com.au/forums/topic/302415-sa-r32-gtr-185k-negotiable/
    • Yeah well per the video it took 15s for the stock unit to start up....even if I give it a few seconds discount for starting that is at least 12 sec before you get a reverse camera if you are trying to leave a park.  The android unit is way faster, but 2016 for the stock unit is a long time ago in consumer electronics
    • Yea that’s why I said ima test them with multimeter and see the reads.
    • Only at idle. Isn’t a problem when rev it seems.
    • @Haggerty This seems silly to ask, but are you confident in your ability to tune the Haltech?
    • Next on the to-do list was an oil and filter change. Nothing exciting to add here except the oil filter is in a really stupid place (facing the engine mount/subframe/steering rack). GReddy do a relocation kit which puts it towards the gearbox, I would have preferred towards the front but there's obviously a lot more stuff there. Something I'll have to look at for the next service perhaps. First time using Valvoline oil, although I can't see it being any different to most other brands Nice... The oil filter location... At least the subframe wont rust any time soon I picked up a genuine fuel filter, this is part of the fuel pump assembly inside the fuel tank. Access can be found underneath the rear seat, you'll see this triangular cover Remove the 3x plastic 10mm nuts and lift the cover up, pushing the rubber grommet through The yellow fuel line clips push out in opposite directions, remove these completely. The two moulded fuel lines can now pull upwards to disconnect, along with the wire electrical plug. There's 8x 8mm bolts that secure the black retaining ring. The fuel pump assembly is now ready to lift out. Be mindful of the fuel hose on the side, the hose clamp on mine was catching the hose preventing it from lifting up The fuel pump/filter has an upper and lower section held on by 4 pressure clips. These did take a little bit of force, it sounded like the plastic tabs were going to break but they didn't (don't worry!) The lower section helps mount the fuel pump, there's a circular rubber gasket/grommet/seal thing on the bottom where the sock is. Undo the hose clip on the short fuel hose on the side to disconnect it from the 3 way distribution pipe to be able to lift the upper half away. Don't forget to unplug the fuel pump too! There's a few rubber O rings that will need transferring to the new filter housing, I show these in the video at the bottom of this write up. Reassembly is the reverse Here's a photo of the new filter installed, you'll be able to see where the tabs are more clearing against the yellow OEM plastic Once the assembly is re-installed, I turned the engine over a few times to help build up fuel pressure. I did panic when the car stopped turning over but I could hear the fuel pump making a noise. It eventually started and has been fine since. Found my 'lucky' coin underneath the rear seat too The Youtube video can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44&t=6s
