High compression pistons, larger bore, balanced bottom end, stiff valve springs, aftermarket ecu, higher rev limit (assuming it is still making power)
with an na, you have engine capacity, head + ancilliaries flow, and rpm as your basics.
So if you had a 3.1/3.2L spinning to 7000rpm......
(going to a larger bore may not be a good idea, i dont know, im not an rb30e na tuning and motor building expert. its a good idea but i dont know if it will hinder the engines ability to rev or something)
my rb30e is getting a bit sick....
how much did each of your mods cost, who did it, what exactly is the mod, where is peak power, whats the powerband like etc???
https://www.sau.com.au/forums/topic/30243-rb30-mods/#findComment-615498
the cam is a SURECAM (btw surecam make all the cams for chiptorque, and for the rb30 hp1,hp2,hp3 it's the same cam)
headwork was also done by surecam. double springs, lifter boxes machined, port-n-polish.
104rwkw's on the chiptorque dyno, power comes on strong 2500-7000
https://www.sau.com.au/forums/topic/30243-rb30-mods/#findComment-615645
  • 3 weeks later...
without n2o or turbo!
Turbo is probably the best bang for buck though! can probably pick up the bits you need for under $1k, and run low boost (6psi or so) on standard n/a block without too many dramas.
or the twin cam head conversion also (may as well get a turbo head put on if you're doing that).
https://www.sau.com.au/forums/topic/30243-rb30-mods/#findComment-638082
  • 3 weeks later...
let us know how you ran at willowbank?? i heard something about a 15.2 or something worse then previously..
went to willowbank and only got one run in. there was a huge storm and the event was cancelled. heaps of wheel spin and ran a 15.3.
got it tuned at chiptorque, not a lot more power, a little more topend.
the single afm is the holdup, once i get enough $$$ i'll install a mircotech.
with this setup as is i should be able to run quicker than 14.8, but with the tt/b's i have lost some bottom end power so i'll need to change diff gears....maybe
next time i go out to the track i'll put on some 14's and run standard rear suspension, should help the traction probs.
https://www.sau.com.au/forums/topic/30243-rb30-mods/#findComment-666976
not enough!!!
it was only 4rwkw's, the total cost of the tt/b's was $200 plus dyno tune. so about 400 all up!
i really need to piss off the standard airflow meter! i was thinking...hole in the bonnet, round air filter, bonnet scoop.
BTW......for those that dyno there car in 3rd gear, i made 108rwkw's in 4th and 128rwkw's in 3rd.....
https://www.sau.com.au/forums/topic/30243-rb30-mods/#findComment-667165
4rwkw?? that's bugger all! I've seen way bigger improvements with an XF throttle body conversion than a twin throttle setup. How was your torque? improvement? I noticed more torque with the a twin throttle setup then outright horsepower. but then again, I think the twin throttle setup is more wanker factor than anything. When you going out next?
https://www.sau.com.au/forums/topic/30243-rb30-mods/#findComment-675743
Had my car dyno tuned (again) on the weekend. Told the operator to do a run in 3rd gear and another in 4th gear, made 1-3hp difference between the gears (less hp in 3rd). Don't know where you get an extra 20kw from changing a gear?!?
https://www.sau.com.au/forums/topic/30243-rb30-mods/#findComment-678908
i had it dyno'd at chip torque by Lachlan Riddel (the owner) so ring them and ask him.
Should take the car down there just for a couple of power runs and get a comparison. I was told it's more than likely the way the dyno has been calibrated.
Anyway, I've been told not to reveal my hp figure but I'll be honest with you, we did loose hp but we always knew we were going to with the mods we did.
https://www.sau.com.au/forums/topic/30243-rb30-mods/#findComment-683815
    • Hey guys, I’m a veteran detailer with years of hands-on experience. I’ll be sharing quick, effective detailing tips to help you keep your Skyline (or any ride) looking its best. Got a question? Fire away!
    • I guess when I say it's a POS I mean.. the solution and the stuff has the capacity for maybe... 1 spot. You know, as a spot cleaner. What I really *want* is the ability to do an entire car, all upholstery, all carpet, mats, all seats, door card inserts, A pillars, roof liners, etc. In one go. I get lured by all the jank that comes out and think "I'd like to be able to clean to that degree"
    • I've got one (not the car one, the domestic spot cleaner one, which is basically the same jobbie) and have driven it hard for hours and hours at a time. Grimy sofas, 6' floor rugs, etc. I'd blame your specific example rather than the whole category. I haven't used mine in the car, because.... you know, it's my car. So there is no-one else's ball sweat in the driver's seat, there's no kid food/drink spills or hand prints inside because they've never had an opportunity to put them there. You know, basic, standard Skyline rules.
    • I normally run with I think a 10mm, and definitely use the second handle you can add to a drill. They hurt when they bins up!   For the crush tube, once all subframe is clear, I'd try some stilsons and see if I can get it to start to twist.
    • Probably because they couldn't, because the use of the variable resistor to create a "signal" in the ECU is managed by the ECU's circuitry. The only way that VDO could do it would be if they made a "smart" sensor that directly created the 0-5V signal itself. And that takes us back to the beginning. Well, in that case, you could do the crude digital (ie, binary, on or off) input that I mentioned before, to at least put a marker on the trace. If you pressed the button only at a series of known integer temperatures, say every 2°C from the start of your range of interest up to whatever you can manage, and you know what temperature the first press was at, then you'd have the voltage marked for all of those temperatures. And you can have more than one shot at it too. You can set the car up to get the oil hot (bypass oil coolers, mask off the air flow to oil coolers, and/or the radiator, to get the whole engine a bit hotter, then give it a bit of curry to get some measurements up near the top of the range.   On the subject of the formula for the data you provided, I did something different to Matt's approach, and got a slightly different linear formula, being Temp = -22.45*V + 118.32. Just a curve fit from Excel using all the points, instead of just throwing it through 2 points. A little more accurate, but not drastically different. Rsquared is only 0.9955 though, which is good but not great. If you could use higher order polynomials in the thingo, then a quadratic fit gives an excellent Rsquared of 0.9994. Temp = 2.1059*V^2 - 34.13*V + 133.27. The funny thing is, though, that I'd probably trust the linear fit more for extrapolation beyond the provided data. The quadratic might get a bit squirrely. Hang on, I'll use the formulae to extend the plots.... It's really big so you can see all the lines. I might have to say that I think I really still prefer the quadratic fit. It looks like the linear fit overstates the temperature in the middle of the input range, and would pretty solidly understate what the likely shape of the real curve would say at both ends.
