Hey guys,
Curious to know what works in getting the front cam oil seals to do their job properly. I recently had my engine apart and upon putting it back together i reused the old cam oil seals as they looked to be in decent condition and didn't use any gasket goop around the edge as has been suggested by some, and now find I have a slow oil leak out the exhaust side..
I've just picked up two new seals from Nissan and am about to go and install them. From factory it appears nissan use some gasket maker around the outside face of the seal, is this something that is usually done? Is the gasket maker applied on the seal which is then pushed onto the end of the cam, or is this something to be done before the bearing shell is torqued down to make sure all excess gasket maker is removed?
Thanks for your help :blink:
https://www.sau.com.au/forums/topic/302473-gasket-goo-on-cam-front-oil-seals/
No, Nissan do not use anything around the cam seals.
I use 3bond around them anyway to be safe as it doesn't hurt
The only sealant that goes there is under the front corners of the cam cover gaskets. If you don't have sealant there or have removed the sealant blobs from the front, then that is where your leak will be coming from. It also doesn't help to be dodgey and not replace a $5 seal.
small dob on each side of the cam caps (you will see a small groove on the outside front edge, the sealant needs to be placed outside this groove)...then another small dob in the corners when putting the cam covers on...never had one leak.
hey guys! i've been having this problem for a while! , i went and brought 2 new rocker gaskets... i put them on and its still leaking oil, what do you guys recommend to do? put a little bit of gasket goo around which part????
+1 Paul is spot on here, i had leak issue and kept throwing on new seals and still leaked, then realised its coming out the little corners of the front cam caps, just chuck a dob of goo on each corner side and therefore its totally sealed, its easy to work out where the nissan seal is gonna seal and the gap between the cam cap and the rocker cover seal will seal, then theres that little section where there is no seal from inside to outside at all on the corner edges.
Edited by unique1
Yeah, I ended up going ahead last night.. used some goo around the outer edge of the gasket and a tiny drop under the cam caps (This is where it was from factory..), took her for a bit of a burn just then and no leaks thus far.. touch wood! :blush:
It's supposed to go between the gasket and the corner of the first cam cap. If you put it anywhere else on the sides of the cover it will end up leaking again. The rubber needs to bite into the aluminium and the silicon prevents it from doing so. It is necessary to have it in the front corners though. You don't need to have it under the cam caps but putting it there doesn't hurt unless you cover the oil seal return holes.
where? could you show me in the pictures? im confused...............
How is it not easy to understand? The location has been spelt out about 5 times already.
Front of cylinder head
Front cam cap
Corners where cam cover seals have sharp edges
Put silicon on the cylinder head in those corners.
Or another way to explain it:
Take off the cam cover, look at the very front of the seal on either edge of the archway. Where the sharp corners of the seal are, put silicon on the head where those corners sit.
The oil seals on the front of the camshaft: put some silicon on the outer edge and some grease (rubber or other it doesn't matter) on the sealing surface.
Oil leaks gone
There is no half moon at the front...only at the back.
Is this a prank call?
he is refering to the no.1 cam cap...but we all know the 1/2 moons are the rubber bush fitted to the rear of the head. Bad choice of word only.
    • Cheers. Skyline is back on the menu, can’t get rid of it. It’s like a child you don’t want, or herpes
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
