hey everyone
Alright so the last week or so i have been getting a rb25det installed into my r32 gts-t, everything has been going fine in the conversion however there is one problem i have run into and that is the engine wont turn off. i do have a turbo timer (apexi pen) however i set that to off mode and yet after taking the key out off the ignition the car seems to keep running for 5-10 seconds and then turns off.
Would any body be able to give me some ideas into what i could check for, could it be something to do with the wiring? we used a rb25 ecu as the engine is a S2 rb25det with vct.
If any one could help or has run into the same issue before please let me know.
Cheers, Niran
https://www.sau.com.au/forums/topic/302480-engine-not-turning-off/
Seeing as you've dropped a new engine in, I doubt this is the problem, but is there an alarm/immobiliser installed?
Some mongoose ones have built-in turbo timers that you wouldn't even realise are switched on, until you go to turn the car off..... and it stays on.... lol
dare say the turbo timer is still an issue, remove it or disconnect it fully and see how that goes.
hey man, will keep going through wires i doubt its that as i had the same one on the rb20 engine and when put on "off" mode it would turn car off as soon as the key was taken out
really, im not to sure exactly what one i have but i will look into that.. however this never happened with the rb20?? is there something that could have caused this to happen?
Edited by niran
how does the car turn off? is it an instant click and its off? or does it die down and kind of stall?
im glad you asked that, its a die down stall so basically its running then starts to stall and stop
sounds like something is backfeeding into your ingition, check all of your wiring as well as your earth points in the engine bay.
it could be your alternator or (most likely) another accessory that stays on 5sec after you turn the key off. stay in the car and switch it off, keep an eye/ear out for accessories (deck, lights, electric fans etc..) that stay on while the car is on, and turn off at the same time.
see if you can track it down that way.
is there anything special you've added to the car like electric fans? or is it a straight swap with nothing extra added?
hey man will try all this
was an upgraded fuel pump added/modified?
yes there was, we had a bit off problems with it from the start when trying to get it started, i have a r32 gtr fuel pump installed that then has been re-wired using the original fuel pump 12v as a trigger switch to run the new relay that feeds power straight from the battery so it gets 13.8 v constantly..
however this set up was run in the rb20 also, do you reckon this could be the problem?
i sure do.
use the standard 12v as your +ve terminal and see if it shuts off instantly. if it does, your relay is whats causing it to stay on.
awesome thanks man, will go to the workshop and try it out
niran
  • 9 years later...
    • For these last 7 years of ownership, I've always had to use a small scissor jack under one of the front tow hooks to raise the front just enough so my low-profile jack fits under to reach my subframe jack point. I'm beginning to get annoyed of always having to do this. Are there any lower low-profile jacks that fit under the gtr lip on a dropped car?
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
