I've gone for a more standard set up on my car with smaller turbos and back to standard cam shafts etc, I have a Triple plate clutch which I now feel is not needed, this car will see no track work or nights at Calder, Im just after a daily driver now that will be more suited to day time traffic and feel like a standard car.
The car will be running around 350 to 360rwkw with the final tune, I've been told a twin plate organic clutch may suit my needs, I was wondering if anyone was using such a clutch and how they find it, any comments would be of interest, Cheers Guys.....
Correct me if i'm wrong, but i think if you spend just a couple of hundred dollars more than what you pay for an exedy or whatever organic twin plate clutch, you can/should get a Nismo Coppermix Twin plate clutch.
It has a stock clutch pedal feel and it makes your car very drivable whilst being able to hold whatever power you might have in future if you get bored of your current power again. As a daily driver, you wouldn't want to be stuck in a jam with a heavy twin plate clutch.
I've looked at the coppermix and yes a more friendly clutch but still with some bite, they still rattle, having had an xtreme twin plate and now a exedy triple plate, Im over it, Im hoping the organics will have less noise but I expect a much better feel as Melbourne's traffic is pretty bad now, the box is coming out soon so it's a good time to do the clutch............I've just got off the phone from Jim Berry for two hours, had a good talk about his single plate up grade with a lower clamp pressure that may suit my needs, he said it will have the slip I need to take off at the traffic lights as well as the grip in the clutch when needed, the twin plate organic will still rattle so its sounding like the Jim Berry clutch maybe a good clutch to consider, easy take offs are important to me and it would just top the car off is this was the case, any comments would be of help.
Fark if you could hear a "rattle" from the Nismo Coppermix clutch, your hearing must be super sensitive. Never heard mine rattle and i really love the sound of a rattly clutch.
I've heard good and bad things about the Jim Berry clutches. Never going to be as good or as comfortable to drive as a Nismo Coppermix though :blush:
Point taken, that's why im doing a bit of research, I've never heard one operate before so I wouldn't know, the topic as been done to death for some but the feed back has been helpful, the clutch has been the hardest decision I have had to make so far and it gives me something to mull over.
Thanks for the comments.
My mate smashed two of those Jim Berry clutches in a matter of a month. He is making a fair bit of power though.
Hey mate, why don't you give Racepace a call for one of their custom single plate clutches. It will hold your power and are very street friendly, smooth and quiet. They are local aswell so it's easier, i'v got one in my car so if you want to try it out before you make any decisions let me know and we can meet up. They open next week on Monday I think.
Cheers
i have the beefiest Jim Berry in mine - compared to a stock GTT clutch it's definitely firmer but not noticeable now and i don't think any issues in traffic.
not sure if there is a real need to blow massive money on Jap items when you have 3 good clutch builders here in oz for less money. Jim Berry, NPC and Direct Clutch - i'd go either JB/NPC personally.
Thanks guys, since Ive spent $3g on a clutch already, Im thinking I wish I had of brought a Nismo Coppermix and that would have been the end of that one, I have spoken to both Ben from Race Pace and Simon from Nizpro who put me on to the idea of an organic clutch. (hard to beat for feel)
Don't get me wrong, I still think the Exedy triple plate is a great clutch (a bit to much grip for me) but it smash 3rd gear on a STD box the very first time I stuck the boot into it, and that was on low tune.
The box is coming out with in days, PPG is supplying a replacement upgraded 1st gear so was thinking clutch change now! I think I've got time to wait for Nizpro or Race Pace to open before the box goes back in so I will be chatting with them very soon, I still like the Jim Berry but I must be getting old cause Im favoring the organic clutch.
Hey Miran, I would love to give your clutch a try, PM me and I'll give you a call.
Thanks to all that helped!
    • jeebus. glad you weren't under it while performing the stunt. Also thanks for the link to the wheel measurer, exactly what I needed
    • In the older stuff there were very significant differences 2wd to 4wd, for example Stagea had strut front end for 2wd and double wishbone for 4wd so it was not minor to swap. From poking around the 2wd v37, it *looks* like it might be more possible; some of the parts specifically have "2wd" stamped on them which suggests the platforms are more similar. You'd still want to start with a 4wd half cut to swap stuff from though. I'd suggest if you don't have a tune on the ECU you don't really need one on the trans either. Throttle mapping is in the ECU side (and you can always use a Roar Pedal if you want the throttle to actually respond to your foot), and really if you are happy with the stock power you probably accept the stock trans behaviour too....its all made to be "sporty" not racey.
    • So, updates. I have not washed the car since it came back from Tassie. I've driven it around a bit but not got around to actually sorting it out. I DID raise it because I cracked the rear bar leaving a hotel which was very distressing. Interestingly, the car drives more compliant now that it's raised a fair bit (5mm front, 15mm rear). Also noticed that my FR height was 10mm lower than FL. So that's now sorted out, too. I also bought this and had it printed: https://www.etsy.com/au/listing/1576422240/wheel-and-tire-fitment-tool-universal?ref=shop_home_feat_1&dd=1&logging_key=08f604d9fa4cc383550ba985e6ac85cd5cac7fbb%3A1576422240 Now, if I was smart I would have taken my brake calipers off to actually use this correctly but it was evident enough to me that in the region where the caliper was... there was nothing to hit suspension/guard/arm wise. So I'm going with "it'll be fine" after using the tool to hopefully very precisely measure the wheel clearance. Also while doing this, I had the very VERY bad idea of jacking one of the wheels/suspension arms up while the rest of the car was on jack stands. I did this to see how the arm would travel. This all was well and good until the car slid off the stands and went through a fence. So don't do that. Incredibly nobody was hurt and there was only minor damage to the rear bumper as the car didn't have far to slide, and had 3-4 wheels on it. The only damage turned out to be the fence itself which was easy to fix, and a little bit of damage to the fibreglass rear bumper trim. I had already planned to try a touch up paint kit to fix the time I drove into my garage door to see if it'd help in the interim before I get it fixed properly. I used the Dr Colorchip kit after looking online and seeing everyone talking about it. Yes it's made for chips and not huge broken missing pieces and I'll be 500% recommending it for stone chips after using it for stupid things like me. This took about ... 10 minutes and looking at the half assed photo the 30 second job I did on the bumper corner was almost perfect just by using the tiny little brush and painting it in. The sealact stuff to remove over-painting is really useful, so if/when I do it again I'll likely slather the touch up paint well over it and then clean it up with the cleaning solution. The wheels should arrive in a couple of weeks. I am still kinda confident after doing a stupid amount of measuring (and borrowing a set of 18x10.5+15) that they will not fit because I overlooked something, somehow and flew too close to the sun. ALSO R34 GTR guard liners do not fit on a GTT. I bought the undertray brake duct guides and had the wonderful problem of them not fitting my intake, my oil cooler and the liners themselves were even worse. Attempting to fit them won't work in general - You would have to cut them up as another poster mentioned as the bodywork is different on the GTT. At least I can try to resell them. So instead of cutting those up, I cut up my old already-cut-up GTT liners and extended them by using some PP plastic and drilling some 8mm holes for some nissan clips for the 'extra' bit. Because I was happy to cut them I was able to mount them pretty damn forward so I now have some semblance of guard liners, and the brake vents seal the bumper from the bottom. It sort-of-looks like this, to give some idea - If you look at the GTR and then the GTT this is when I realised that I needed to seriously measure as the inside of the rim area is entirely, entirely, entirely different and could not take any internet measurements for granted.
    • If you are Ecutek tuned then these TCU tunes are anywhere from $550 to $700 usd. If you are not ECUTEK tuned, then it gets costly!
