All parts off a R32 Skyline, 93 model. For sale.
Located in Sydney, Ashfield area.
Velour interior seats. Front and back in excellent condition $350
Door trims 2 door model, both $120
Rear quater trims $80
Centre console $30
Stereo air con tunnel /dash suround, $30
Climate control module $150
Dash cluster 105 xxxkm $120
Dash cluster surround incliding all switches $60
Stereo brackets and under stereo compartment $30
Sub in box, pioneer CD stereo, New 6x9 Pioneer speakers $150 the lot.
Front window pillar trims both $60
2 door model, front doors incuding electric morrors, glass and window motor $150 each
Boot lid black, slight damage and no key lock $30
GTSt bonnet in new silver paint $120
Rear wiper arm $40
Indicator stalk and full switch and horn wire $100
RB20det motor, only travelled 82 xxxkm, including stock turbo, air con compressor
all sensors etc $900
5 speed manual gearbox $500
LSD Diff centre $150
Rear discs and calipers all $120
Power steering pump $80
Clutch master cylender $60
Brake booster $ 50
Brake master cylender $50
GTR Side skirts both $150
Interior light $30
Power sunroof switch $80
Reverse lenses both $50 as new
Tail lights $5o each
And much more, too much to list.
Message me or sms me on 0415126075 for quick response
https://www.sau.com.au/forums/topic/302905-heaps-of-r32-skyline-parts/
  • Replies 52
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
