  QWK32 said:
that makes sense, the ones I'm running are Deastchwerks injectors, even though they list them as RB25 NEO injectors they look like 350z (vq?) injectors but use a 9mm spacer to lengthen them to suit the NEO fuel rail. I was looking at the Deka ones too but I would have had to change the electrical plug on the wiring loom to use them.
Plug is the easy part, they are around 10mm longer and hit the plenum on the vq so I had to fit a plenum spacer. Should be easier on the rb's
  eXquiSit said:
QWK32: interesting... going off nengun again... they reckon (for hks injectors anyways) that r34 gtt is same part number as r32/33/34 gtr
chuckie:im looking thru your posts now
thanks!
i dont understand how they can have them listed all as the same thing. especially since GTR injectors are low impedance and RB25 Neo's are high impedance. heres a pic i dug up of the different shapes of RB injectors, they are nismo ones but show the shapes/types the same as the stock ones are. S2 NEO stagea's are the same as R34 NEO, purple ones down the bottom. stock S2 ones look exactly the same only blue. S1 is the same as R33.
yeah apart from needing to change plugs they would be a direct fit. at the time the us dollar was crap so i could get the deatschwerks which are a direct fit no mod injector for the same as the Deka kits were going for.
Edited by QWK32
I have done a fair bit of research in the few weeks on these as I need some 650cc or so
The seimens deka 3/4 length only comes in upto 550cc
The full length ones go over 1000cc
Either can be used, just need to space the fuel rail to suit, plus the plugs are different
Approx $70-75 each plus plugs
full length are used in BA-BF XR6 turbo and I think LS1
3/4 length are from FG XR6 turbo and holden lS2 and LS3
The more expensive options
Biggest nismo are 480cc, I just sold mine to bigger
Blitz used to sell 525cc, I use to use these as well
I think Sard make some
ok so do the 'cheap' injectors offer good quality spray pattern or is it better to go the expensive route n get say sards if you need bigger?
how much power does each cc injector support?
i know there is a bit of difference between setups but what is the norm for say nismo 480cc, etc etc
thanks!
thanks!
My deka's are 610's and 4 hole spray pattern, same as Nismo. I have no issues at all running E85 through them constantly. Around 250kw with plenty of headroom. Theres no way I was going to spend $1500 on injectors.
