All items located in Cairns, QLD. PLease contact me via e-mail ([email protected]) as keeping up with pm's with the only 1 pm every 5 mins rule makes it very hard. I can also be contacted on 0437838032.
Item: Tomei Pon Cams
Condition: Brand new, in original packaging.
Price: $700
Item: Tomei Cam Gears
Price: $300
Item: Tomei Cam Cap Studs
Price: $300
Item: Tomei Valve Springs
Price: $500
Item: Tomei Sump Baffel
Condition: Brand new.
Price: $350
Item: Tomei Metal Gasket Kit
Price: $600
Item: Adjustable R32 GT-R Rear Camber Arms
Price: $250
Item: Mines Style cam cover baffles
Price: $150
Item: Blue alloy alternator pulley
Price: $40
Item: Oil Cooler Kit, Filter relocation
Condition: Used
Price: $200
Item: c's Short Shifter
Condition: Used
Price: $250
Item: Nismo Oil Cap
Price: $100
Item: Nismo Radiator Cap
Price: $100
Item: Greddy Turbo Timer
Condition: Used
Price: $50
Item: Standard Igniter
Condition: Used
Price: $50
Item: Nissan oil pump gasket
Price: $20
Item: Gates Timing belt
Price: $80
Item: Accel coils x 3
Price: $100
Item: Greddy Dual Gauge Pod
Price: $80
Item: ARP Head Stud Kit
Price: $500
Just to be clear. From now on anything purchased off me that is sent via post, i'm not responsible for what happens to it after i drop it off at the post office. Poastage will be the buyers risk otherwise i may as well just dump all the parts in the bin.
Cheers,
Rob
After much sweating the cam gears finally arrived this morning. That's 10 working days or twice the stated delivery time from Austrlia Post. Worth considering Express or Registered next time.
Packaging good and exactly as described.
Thanks.
What brand is the oil cooler fittings and relocation kit Earls, speedflow etc?
Not 100% of the details of the kit as I did not buy it new. The pics show exactly what is included. Oil cooler is sold pending payment.
Cheers,
Rob
haha those radiator caps are $75 brand new from just jap
Right you are. Radiator Cap is now up for grabs @ $70. But the oil cap has increased to $140. Thank you for pointing out the value of these items as I was unsure.
Cheers,
Rob
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
    • So M12 and sealant should be fine?    NPT ” because that’s what I had and what I could get atm.
    • Wouldn’t touch par if they gave it to me. You need to ask how much power you’re looking to make and then add about 50% to it because that’s what you’ll end up making  The factory box says no more at about 350kw or so, the upgraded synchro boxes won’t handle much over 500kw for long and at that point you’re looking at an auto or dog engagement manual,  once you’ve gone dog engagement you may as well go sequential, they cost a little bit more but it’s worth it  also while you’re at it you should upgrade the transfer case with 10 friction plates
