All items located in Cairns, QLD. PLease contact me via e-mail ([email protected]) as keeping up with pm's with the only 1 pm every 5 mins rule makes it very hard. I can also be contacted on 0437838032.
Item: Tomei Pon Cams
Condition: Brand new, in original packaging.
Price: $700
Item: Tomei Cam Gears
Price: $300
Item: Tomei Cam Cap Studs
Price: $300
Item: Tomei Valve Springs
Price: $500
Item: Tomei Sump Baffel
Condition: Brand new.
Price: $350
Item: Tomei Metal Gasket Kit
Price: $600
Item: Adjustable R32 GT-R Rear Camber Arms
Price: $250
Item: Mines Style cam cover baffles
Price: $150
Item: Blue alloy alternator pulley
Price: $40
Item: Oil Cooler Kit, Filter relocation
Condition: Used
Price: $200
Item: c's Short Shifter
Condition: Used
Price: $250
Item: Nismo Oil Cap
Price: $100
Item: Nismo Radiator Cap
Price: $100
Item: Greddy Turbo Timer
Condition: Used
Price: $50
Item: Standard Igniter
Condition: Used
Price: $50
Item: Nissan oil pump gasket
Price: $20
Item: Gates Timing belt
Price: $80
Item: Accel coils x 3
Price: $100
Item: Greddy Dual Gauge Pod
Price: $80
Item: ARP Head Stud Kit
Price: $500
Just to be clear. From now on anything purchased off me that is sent via post, i'm not responsible for what happens to it after i drop it off at the post office. Poastage will be the buyers risk otherwise i may as well just dump all the parts in the bin.
Cheers,
Rob
After much sweating the cam gears finally arrived this morning. That's 10 working days or twice the stated delivery time from Austrlia Post. Worth considering Express or Registered next time.
Packaging good and exactly as described.
Thanks.
What brand is the oil cooler fittings and relocation kit Earls, speedflow etc?
Not 100% of the details of the kit as I did not buy it new. The pics show exactly what is included. Oil cooler is sold pending payment.
Cheers,
Rob
haha those radiator caps are $75 brand new from just jap
Right you are. Radiator Cap is now up for grabs @ $70. But the oil cap has increased to $140. Thank you for pointing out the value of these items as I was unsure.
Cheers,
Rob
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
