Wrecking my 1995 R33 series 1, its turbo Manual,
Located in Adelaide.
this car is not damaged at all, it has been defected.
Engine - $2500
Gearbox - $500
3" exhaust with resinator and cat-back, would only be about 6 months old $400
Front mount intercooler $300
Headlights - Pair $250
Spare wheel - Space Saver - $30
18 inch Lenso Wheels - Multi Stud - about 50% tread - $500
Turbosmart BOV - $70
Whole trims for $250 or PM me for individual pieces and i will let you know a price
Front guards $150 Each
Boot lid with spoiler - $120
Brakes and 5 stud conversion - $800
Doors - $150 each
Bonnet - $100
Taillights $300 Pair
Cluster $70
King Springs - Low - $200
Grill - $100
Headlights - $250 Pair
Complete Boot Carpet - $100
Mirrors - $50 Each
Parcel Shelf - $50
Sunvisors - $50 Pair
Climate Control Unit $50
Floor Mats $40 for 3
Heater/ Air con Box $150
Rear Window $150
Front Windscreen $150
Piece on back of car thats got 'Skyline' written - $50
Centre Console $50
Glove Box - $50
Dash $100
Driver seat - has a rip on side and a mark on it - $80
Passenger Seat $100
Indicators $50 each
Driver window switch $100
Passenger window Switch $50
Door Windows $50 Each
Control Arms $40 Each
Castor Rods $50 Each
Manual Tailshaft $150
Fuel Tank $100
Diff $300
Drive Shaft $60 Each
Will post anywhere at buyers expense.
If i have missed anything that you need, PM me with it and i will give you a price, or give me a ring or text on 0432 317 281
Cheers Jared.
https://www.sau.com.au/forums/topic/303066-wrecking-r33-s1-turbo-manual/
  • Replies 41
Hey Jared
I took yourcar for a test drive last year some time. Sorry to hear about the deffect, im interested in the BOV. Does it have an adapter for the 33 series 1?
Cheers
do you have the plastic frames that go around the inner door handles and the plastic covers that go over the front seat bolts (front passenger seat, rear bolt covers). & what do you want fro them.
Engine - $2500
Gearbox - $500
Doors - $150 each
Bonnet - $100
Cluster $70
Grill - $100
Mirrors - $50 Each
Parcel Shelf - $50
Rear Window $150
Centre Console $50
Glove Box - $50
Dash $100
Passenger Seat $100
Indicators $50 each
Fuel Tank $100
Diff $300
Cheers Jared.
do u stil have engine mounts
    • My guesstimate, with no real numbers to back it up, is it won't effect it greatly at all.its not a huge change in position, and I can't see the air flow changing from in turbulence that much based on distance, and what's in front of it. Johnny and Brad may have some more numbers to share from experience though.
    • Which solenoid? Why was it changed? Again, why was this done? ...well, these wear..but ultimately, why was it changed? Did you reset the idle voltage level after fitment? I'm just a tad confused ~ the flash code doesn't allude to these items being faulty, so in my mind the only reason to change these things, would be some drive-ability issue....and if that's the case, what was the problem? Those questions aside, check if the dropping resistor is OK ...should be 11~14 ohms (TCU doesn't throw a flash code for this) ~ also, these TCU designs have full time power (to keep fault code RAM alive), and I think that'll throw a logic code (as opposed to the 10 hardware codes), if that power is missing (or the ram has gone bad in the TCU, which you can check..but that's another story here perhaps).
    • Question for people who "know stuff" I am looking at doing the new intake like the one in the picture (the pictured is designed for the OEM TB and intake plenum), this design has the filter behind the front bar, but, the filter sits where the OEM duct heads into the front bar, and the standard aperture when the OEM ducting is removed allows the filter to pulled back out of the front bar into the engine bay for servicing, a simple blanking plate is used to seal the aperture behind the filter This will require a 45° silicone hose from the TB, like the alloy pipe that is currently there, to another 45° silicone hose to get a straight run to the aperture in the front bar Question: how will it effect the tune if I move the MAF about 100-150mm forward, the red is around where my MAF is currently, and the green would be where it would end up Like this This is the hole the filter goes through  Ends up like this LOL..Cheers
    • Despite the level up question, actually I do know what that is....it is a pressure sender wire.  So check out around the oil filter for an oil pressure sender, or maybe fuel pressure near the filter or on the engine. Possibly but less likely coolant pressure sensor because they tend to be combined temp/pressure senders if you have one. Could also be brake pressure (in a brake line somewhere pre ABS) but maybe I'm the only one that has that on a skyline.
    • Pull codes via the self-diagnosis procedure. As far as I can tell this is just a sign of transmission issues but not a code unto itself.
