  • Replies 44
still available??? any chance of gettting longer lines or can i get the black kevlar line instead of the braided earls line???
Item: 10 Row Oil Cooler w/ FULL Oil Filter Relocation Kit
Features:
- Keeps engine components at correct running temperature
- 10 row GReddy style oil cooler
- 290x140x50mm with a mega 405cm cooling area (front and sides)
- (-10AN) Male fittings size
- Oil cooler made of aluminium and coated with an anti-corrosive
- Full engine oil filter relocation kit
- Accepts all spin-on M20X1.5 thread size oil filters
- Sandwich plate includes ports for 2 extra gauges
- Comes with all nuts bolts and brackets
- 3 Earls type braided stainless steel flexi oil lines (125, 145 and 165cm)
- Practically a stand alone setup - easy installation!
Has been extensively used on all Nissan RB series engines
$325 including Delivery & Insurance SAU SPECIAL - FREE POSTAGE
Condition: Brand New
Contact: 0401599023 (anytime) OR [email protected]
CUSTOMER INSTALLS - Send us yours next!
Just to confirm - this kit will accept any good quality oil lines that are correctly sized
- Brendan
  • 3 months later...
  • 1 month later...
  • 7 months later...
  • 1 month later...
Hi Brendan,
Do you still stock/able to get these kits? And can you supply a thermostat with "direct fit" fittings for the kit? And a price for that whole package? thumbsup.gif
Cheers, Josh
Hi Brendan,
Cheers, Josh
Hi Brendan,
Cheers, Josh
Forward that PM on to me too please :-)
Hi Brendan,
Interested on getting a kit, just want to confirm, does the Ryco Z145A fit the thread supplied? As Ryco lists it as 3/4-16UNF?
http://www.rycofilters.com.au/catalogue/product/make/Nissan/model/Patrol+GQ/part/Z145A
Cheers, Josh
Edited by blk94r33
Hi Brendan,
http://www.rycofilte...l+GQ/part/Z145A
Cheers, Josh
Replied to Josh
Just ordered kit yesterday. What filter should i be using? can anyone recomend a part no.
Hi,
Any screw-on M20x.15 bolt size oil filter will do - Ryco Z160 from memory but not 100% sure.
You can contact any auto parts store and they should be able to help.
- Brendan
  • 3 weeks later...
I've got this kit on my car. Great kit but I've got to say, it probably works too well... I recommend getting a thermostat if you buy this kit otherwise your oil will take way too long to warm up. I've done a 30 minute drive on the way home from work and my oil temperature didn't move from cold before I put a thermostat on.
I suggest either:
http://www.mscn.com.au/scripts/prodView.asp?idproduct=352
I've read good things about this one and I believe a few people on here use it.
or
http://www.mscn.com.au/scripts/prodView.asp?idproduct=353
I used this type as it is easier than the other one. Seems to work well.
I use the Ryco filter Z148A. Pretty much exactly the same size as the Z145A except with a different thread pitch.
Also the lines are WAAAAYYY too long and had to be cut down to fit on my 32 and would be better if it came with more 90 degree connectors.
Thanks for the feedback - yeah the 15 row oil cooler is very good and keeping the temperature down (maybe too good)!
I will be looking into getting some thermostat's in soon as well, have had a lot of interest in them.
In regards to the length of hosing, a lot of them are fitted to large 4WD's for country driving so they make good use of the length, they are universal in fitment.
- Brendan
  • 5 weeks later...
    • For these last 7 years of ownership, I've always had to use a small scissor jack under one of the front tow hooks to raise the front just enough so my low-profile jack fits under to reach my subframe jack point. I'm beginning to get annoyed of always having to do this. Are there any lower low-profile jacks that fit under the gtr lip on a dropped car?
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
