Cheers mate well i shall have the engine in about a month so will be great timing :P Roughly the same price im guessing. Shall add some bling and performance to the track car :) not to mention simplifying plug changes :)
Ah that sounds like it will work out well then.
Price will actually be slightly lower on the RB20's as they are a smaller unit - once they are here they'll be up on SAU.
So keep your eye out ;)
  • Replies 124
Will do or a PM would be even betterer lol. But yah im always trolling these forums so im sure ill spot it :P
  • 1 month later...
Hey guys tried calling earlier I need a rb20 plenum asap how far off are they and how much please pm me cheers
Hi,
SMS sent.
Keep an eye out on this thread as once the RB20's are in well let everybody know about it.
- Brendan
  • 1 month later...
  • 1 month later...
just some friendly feedback, i bought one today and spoke to brendan in his showroom. very easy to deal with, willing to help and friendly.
thanks for your SAU support!
bj
anyone making big power on these??
Just had a chat with an old customer of ours Chris, after a year of using our plenum he's going to upgrade to one of our 80mm bolt-on TB's.
He's making some very good numbers (check-out that turbo), and the plenum is handling it all no problem! :thumbsup:
  • 1 month later...
Hey mate my build thread has the RB20 plenum on it. Heres a few pics of it installed. Was easier while engine was out lol. Heres a few picks. Note the fittings are not included picked them up seperately. Everything bolted straight up. Just had to widen where the throtle cable where the nuts tighten onto. U also can use the RB20 cable no need for a longer one :)
  • 3 weeks later...
Hey guys, how do these stock up against the Plazmaman plenums? I'm undecided on whether I want to run a FFP as I can't see any definite power gains and there have been several cases of where power has gone backwards, which is why I'm cautious. Apart from easier access to some components, what would your advice be? The car is a street legal, which sees occasional track/drift days.
Also, can it come in a raw finish for a stock look?
Thanks guys.
Thanks guys.
Hey,
We've had some great results with these plenums, if you go through this thread and other's an SAU there is a fair bit on them. We don't stock plazmaman plenum's so can't comment on them aside from being a lot more pricey!
We can do these raw cast or just a rough polish not chrome electroplated.
- Brendan
Could you attach some pictures regarding the raw cast and rough polish ones?? cheers
Hi,
Here is a link to a sample of the raw cast finish; http://e4eonline.com..._CastSample.jpg
The polished finish is similar to the chrome one pictured however less shiny.
If required I can source some more images.
- Brendan
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
