  • Replies 53
HAHA
I hardly eva use aircon . . . Drains too much powah
Tell me about it. My compressor is on all the time (yes even if I didnt switch on the a/c) because when I install the a/c, the electrician had to run new wires (car doesnt come with it) and said its a lot easier to just hook power to the compressor (forgot detail and cbf).
sounds like the dodgy bastards who worked on my car! :D
Yea... I wouldnt blame him cause he's gotta find the whole schematic diagram of the car. TBH, I was very surprised that the car loom doesnt have the a/c bits.
Anyway you guys wanna come tomorrow night or you're sticking to baskin?
harry's for the epic failing lose.
question answered?
I'm not trying. Its already happening like loose nuts. :huh:
ps: those that come for dinner dont normally go to Baskin anyway. And I'm probably the only one other than Michael that actually drive up.
hey brendan, its mitch...mate i wont be able to make it out in the sss tonight..as ive just put my whole $1300 pay cheque on the GTR!....now all is registration and ill be back... however if u wanna pick us up..huh hum....call me..i just called ya!!!!
edit...will be in a 35 skyline....see yas at freedom ppl!!!
Edited by nissan32GTR
Was that you boys in the middle majority were white skylines? Only saw ya's on the way out gave someone a wave...had to jet early to meet up with my mate in his Evo. I haven't been to Harry's in a while looked a lil unpopular???
Yea, saw Duh19 past us. Should park and say hi mate. The crowd tonight wasnt that bad considering all the supras that were there. But the carpark was pretty pack towards the end around 830ish.
Was a good night!!
Some nice cars out that's for sure.. ;)
Good to see everyone too.. :(
DAN?????????????? Where the hell were you?? ;)
Great night!
ps. Beck, next time ima try an steal that parking space lol
    • Great work! Thanks for documenting the process.
    • How would you even adjust the clutch if the pedal already has the correct free play? The operating cylinder has no adjustment in mounting position or rod length. On pull style clutches there is also no ability to adjust the bearing carrier. Push type I can see how adjusting the carrier height makes it all work.   If this is the twin plate clutch did you verify that your friction disks were oriented correctly? It's not mentioned in the directions at all you just have to notice that one side the friction disks have a part number on the hub fingers and a subtle coning to those fingers. Another thing that I noticed was if you put the friction disks in backwards the pressure plate fingers will not be even and flat when the clutch is installed.
    • yeah, mechanically, it is probably do-able, off the top of my head, there would be the transfer case, which I believe will bolt up to the rear of the RWD transmission, the shorter rear tail shaft. A front drive shaft, front diff, engine upper sump, front drive shafts, front hubs and front AWD struts (they are shaped around the front drive shafts), LCAs (at the very least from the front suspension) oil cooler.  You might want the rear diff from an AWD too, so you can be certain the front and rear diff rations are identical.  Who knows what brackets and mounts you might need.  So a whole doner car might be the best option if you need to maintain RHD. Then actually making it work, that would be a whole different story.
    • Take the fall as a warning sign for future endeavours  Stay safe mate
