Been having a discussion on supraforums about whether or not the end muffler has any major effect on the sound a car puts out. Obviously the difference between a 1" pee shooter and a 5" cannon will be different, but if you had two of the same car, with the same set up all the way back to the rear muffler would two different cannons make a large difference to the noise? I figure a cannon is a cannon and brands will only change the note slightly.
Anyway, the reason I'm bring this here is because I currently have a Varex muffler on my car, but my car is quiet enough not to need it in the first place. A mate of mine wants to buy it off me, so I told him to buy me a replacement and I'll give it to him for free.
IF there is a difference, can anyone recommend me a decent muffler only (not interested in a catback, already have a custom system) to replace mine with? I asked on the Supra forums but compared to SAU they're utterly dead.
Thanks for any input guys, and sorry for bringing another exhuast thread in here. :huh:
https://www.sau.com.au/forums/topic/303709-mufflers/
the shape and size of the muffler plays a big part on how it sounds. if you get 2 cannons roughly the same size then they will more than likely sound very similar. but if you get a cannon and compare it with a big oval muffler then the sound will be totally different as the oval mufflers have a lot more packing in them and generally make the car quieter and generally give a less raspy sound.
a perfect example is some of the lancers etc you see getting around. they have cannons on them and often sound like a rotary once they floor it. yet if you see one with an oval muffler on the rear they just sound a bit deeper and louder than normal and don't usually sound like arse.
as for cannons being cannons, as i said to start with, size comes into it as a bigger bodied cannon will be quieter than a smaller bodied cannon with the same pipe though the centre. this is because they have more packing in them to soak up the sound. also better quality cannons will generally be quieter as well for the same size body simply because they put more packing in them and better quality packing.
https://www.sau.com.au/forums/topic/303709-mufflers/#findComment-5032141
Thanks for the info mate.
I actually wrote out a rather long and indepth reply then got some error when I tried to post it and lost it.
I was mainly asking if different materials have an effect, like titanium, and what kind of effect.
Also, what would recommend for me. I want to keep my racey, high-pitched note, or even improve it.
Cheers.
https://www.sau.com.au/forums/topic/303709-mufflers/#findComment-5034847
It will. Different materials will have different tones. I'm not sure how much volume itself will be affected.
Mild steel tends to have a deeper tone than stainless. Titanium exhausts tend to be very thin-walled, which makes them a bit tinnier as well.
https://www.sau.com.au/forums/topic/303709-mufflers/#findComment-5035451
yeah the same goes for stainless. it is usually slightly thinner than mild steel as well, so gives a slightly different note. however for the actual muffler itself this effect is lessened compared to the piping as there is the muffler packing to reduce the difference.
https://www.sau.com.au/forums/topic/303709-mufflers/#findComment-5035798
    • To back this up, I'm always looking on the outside, seeing the level, and then opening it up anyway, as I'm worried the level I've looked at, is more so a scunge line. Then you end up dipping your damn finger in it too depending on the type of tank you're looking at just to make sure I'm not going insane.   PS, Mark, polish up the none moroso one a bit and then give it a clear coat. The Moroso one looks to be way shiner (not mirror polished, just shinier) and it'll still look weird with the two different alloys beside each other. Either that, or Id probably paint them a flat black...
    • Good old Orange Park hey... 😛   f**k I miss that race track
    • lo, it was a death trap. Good times. Got any Fatz Drift Day DVDs still available?
    • Yes, overthinking. Many PS reserviors are completely opaque. Our Skyline ones, for example. Have to remove lid, peak inside, swirl the dipstick, try to remember how to read it, etc etc. Normal. Radiator overflows are often sufficiently opaque and scunged up that you can't see the true level inside anyway, and have to open and have a peak. Besides which, I replaced the (massively expensive, even back then) plastic overflow in my Alfa GTV, back in the '90s with a stainless one that I had a good fabricator make up to be dimensionally same-same, that looks remarkably similar to the Bogan's Moroso one above, and I never suffered any particular paranoia that I didn't know how much coolant was in it.
    • Looks great, but I'm always concerned that it makes it difficult to see what level the fluids are at. Am I overthinking this?
