Been having a discussion on supraforums about whether or not the end muffler has any major effect on the sound a car puts out. Obviously the difference between a 1" pee shooter and a 5" cannon will be different, but if you had two of the same car, with the same set up all the way back to the rear muffler would two different cannons make a large difference to the noise? I figure a cannon is a cannon and brands will only change the note slightly.
Anyway, the reason I'm bring this here is because I currently have a Varex muffler on my car, but my car is quiet enough not to need it in the first place. A mate of mine wants to buy it off me, so I told him to buy me a replacement and I'll give it to him for free.
IF there is a difference, can anyone recommend me a decent muffler only (not interested in a catback, already have a custom system) to replace mine with? I asked on the Supra forums but compared to SAU they're utterly dead.
Thanks for any input guys, and sorry for bringing another exhuast thread in here. :huh:
https://www.sau.com.au/forums/topic/303709-mufflers/
the shape and size of the muffler plays a big part on how it sounds. if you get 2 cannons roughly the same size then they will more than likely sound very similar. but if you get a cannon and compare it with a big oval muffler then the sound will be totally different as the oval mufflers have a lot more packing in them and generally make the car quieter and generally give a less raspy sound.
a perfect example is some of the lancers etc you see getting around. they have cannons on them and often sound like a rotary once they floor it. yet if you see one with an oval muffler on the rear they just sound a bit deeper and louder than normal and don't usually sound like arse.
as for cannons being cannons, as i said to start with, size comes into it as a bigger bodied cannon will be quieter than a smaller bodied cannon with the same pipe though the centre. this is because they have more packing in them to soak up the sound. also better quality cannons will generally be quieter as well for the same size body simply because they put more packing in them and better quality packing.
https://www.sau.com.au/forums/topic/303709-mufflers/#findComment-5032141
Thanks for the info mate.
I actually wrote out a rather long and indepth reply then got some error when I tried to post it and lost it.
I was mainly asking if different materials have an effect, like titanium, and what kind of effect.
Also, what would recommend for me. I want to keep my racey, high-pitched note, or even improve it.
Cheers.
https://www.sau.com.au/forums/topic/303709-mufflers/#findComment-5034847
It will. Different materials will have different tones. I'm not sure how much volume itself will be affected.
Mild steel tends to have a deeper tone than stainless. Titanium exhausts tend to be very thin-walled, which makes them a bit tinnier as well.
https://www.sau.com.au/forums/topic/303709-mufflers/#findComment-5035451
yeah the same goes for stainless. it is usually slightly thinner than mild steel as well, so gives a slightly different note. however for the actual muffler itself this effect is lessened compared to the piping as there is the muffler packing to reduce the difference.
https://www.sau.com.au/forums/topic/303709-mufflers/#findComment-5035798
    • The issue now is the 'fuel cut' while driving, and when it happend, it does not stall. This, I did not test the fuel pressure while driving as I cannot with a fuel pressure gauge. I do have Nistune logs, yes. I have also replaced the MAF Sensor.   Also related to the FPG Fuel Hanger – I just realized that I need a Deutsch Crimp Tool to crimp some cables for the FPG Fuel Hanger. Need to purchase additional cables as the kit only included 2, which are for the float. FPG has not responded to my emails so far since purchasing. I thought about taking it to someone and having it done professionally, but I am reluctant since everyone I took it to messed up in some way.
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
