Hi there,
I have an R32 gtr and i'm planning a big rebuild. I'm looking for around 370rwkw every day car with maximum response.
I will be running HKS 2.8L Stroker with HKS Gtrs Turbos plus lots more. Can anybody recommend camshafts or a camshaft kit that would best be suited to my needs.
Thanks,
Jamil
https://www.sau.com.au/forums/topic/303739-which-camshafts/
  • Replies 56
This should be a good debate, always is :rolleyes:
Some will say stock, some will stay 260's, some will say 270's+
One thing however is for certain. Your turbo choice for 370rwkw - is bad.
Those turbos are 450rwkw+++. So there is little point in using them for that power goal.
If you want max response, you want the Garrett -5's (AKA HKS2530).
They will be coming into boost in the mid-high 3000rpm range, pull to 8000rpm and make you a lazy 400rwkw.
https://www.sau.com.au/forums/topic/303739-which-camshafts/#findComment-5032468
Yeah this will be a good thread!
Heaps of people have tried heaps of different setups and will have different things to say.
Ive got a 3L and GTRS's with 270's and changing to 260's to bring the power on a bit earlier :D
https://www.sau.com.au/forums/topic/303739-which-camshafts/#findComment-5032656
ive tried 260's with RS's...they were rubbish.
transformed the car with real cams installed and a proper head. Brought the power on 1000rpm earlier. This was an actual back to back test on the same engine/car and dyno with the same operator. Even one of the most experienced GTR tuners in the country thought his dyno was playing up as the difference was unbelieveable. He rolled another car on to check it was reading right, then rolled ours back on and it made the same power (less 2KW).
some people don't actually understand how a forced induction engine works...with a 26 stroker you would be mad to do what you have suggested above as it will leave a massive hole in your torque curve and leave you wondering why its not performing. 260's have nowhere near enough valve lift to move the air required for those turbo's. Their is a fella up here in qld who just tried the above with his 26/30 and went backwards as i told him it would. His T51R that he installed after he decided to ditch the RS's for actually came on earlier as it was recieving double the cylinder pulses the RS's were for each engine revolution keeping the turbo shaft speed high. The RS' sare not an easy turbo to get right when using in a twin combo...but when right they are outstanding. Over 500AWKW at 25psi, a 5000rpm curve of peak torque and 9 second drag passes out of a 1500kg car is my proof that i know how it needs to be done.
Jamil, if you need hand with the build send me a PM.
Edited by DiRTgarage
https://www.sau.com.au/forums/topic/303739-which-camshafts/#findComment-5032728
Ive got a 3L and GTRS's with 270's and changing to 260's because i cant handle the awesomeness :D
Fixed.
https://www.sau.com.au/forums/topic/303739-which-camshafts/#findComment-5032737
*sigh* ....well this was going to be a decent thread.
Good luck with the build :P
Btw Dave, you can have a drive of my car in about 2 months when it comes back home. You'll take back that comment pretty quickly :D
https://www.sau.com.au/forums/topic/303739-which-camshafts/#findComment-5032777
What?...thread is now indecent because you don't agree with something someone has said. So there is something a little wrong with someone sharing knowledge that has been there before. You have a point though...an engine that produces over 1200nm of peak torque at 4500rpm, that revs to 9500rpm and makes over 1/2 a megawatt at the tyres is so indecent it should be considered porno.
https://www.sau.com.au/forums/topic/303739-which-camshafts/#findComment-5032811
The sound of 270s on an RB is porn :D
Back on topic:
As Nismoid said GTRSs are too big for 370awkw, for response you need to make your target power level with the smallest turbo/s.
But what power you will get will never be enough. If this build is for "real" i would put on T51R (KAI). Will make over 400awkw and have fairly good response.
And have a set of 260 degree 10.25 lift cams in there.
https://www.sau.com.au/forums/topic/303739-which-camshafts/#findComment-5032855
I'll tell you one thing, nothing starts arguments like a good discussion about camshafts.
I'm currently running a 26 with 264IN and 272EXH and I've had every man and his bloody dog try and give me advice, drives you mental after a while.
My advice is to look at the guys who have been there and done it and generally it will save you a whole lot of coin.
Back OT, I agree with R31Nismoid and as im sure the other gentlemen in this thread will tell you, your better off choosing a turbo setup on the smaller end of the scale to acheive this power level (read Not GT-RS) as you have stated response is your ultimate goal.
Cheers,
Mitch.
https://www.sau.com.au/forums/topic/303739-which-camshafts/#findComment-5032942
1200 newtons of tractive effort...not actual torque at the crank :D
I still dont see how massive cams can bring the power on earlier...its goes against every thing related to engine tuning i know.
More lift plus more duration = more power at high revs and less down low.
Big cams need high compression to work properly...so on a turbo car that means more air flow, it might make more power at less +ve manifold pressure, but ill bet the turbine shaft speeds are higher.
I feel that a 264/268deg total duration (230/235 @ .050) with 10mm lift should still give reasonable cylinder filling at normal street revs while still allowing the 2.8 to dig deep at higher revs.
Make sure you do somthing with the ports aswell as discuss cams with your head guy, not the bloke selling you the HKS turbos with about 100% mark up. As most mechanics will tell you what ever you want to hear to get at your credit card.
https://www.sau.com.au/forums/topic/303739-which-camshafts/#findComment-5032969
^^ Doesn't mean they offer anything :D
Agree though, bad turbo for 370rwkw regardless.
What cam's was this running?
Not supersize-me cams that's for sure....
Factory OEM cams :D
So it's very much as i said earlier - a very debatable topic that will go every which way like shit off a fan.
Everything works for everyone, how they take choice to do so.
But come on - does it need to go to PM? Lets keep it out in the open (and stop editing your posts :P)
https://www.sau.com.au/forums/topic/303739-which-camshafts/#findComment-5032972
Apart from standard cams what else was used on the engine?
the amount of r & d that went into building that engine if put into a $$ figure was about $200K. That was stated directly to me in person by the engine builder.
Zebra your coventional thinking you have quoted is correct on a vacuum drawing engine (atmo). It doesn't necessarily go the same way with forced induction. Would you run a small cam in an atmo engine that runs 15:1 static comp and expect it to make lots of power early...no way. How do you expect to get good cylinder fill and properly burn the mixture.
The thread was about RS' turbo's on a 2.8ltre. I wouldn't contemplate running RS's in a streetcar as it takes a big dollar head to compliment them...but if dollar figure is not an issue...yeah go for it...if not put -5's on it and enjoy a car that will fly under the radar and spend the saved $$ on a good brake kit for track racing it every now and then.
https://www.sau.com.au/forums/topic/303739-which-camshafts/#findComment-5033115
Same could be said for a lot of motors, workshops spend time and money to learn over the years.
This is the end result. To have it "built" would not cost 200k once knowledge is known, which it is.
Agreed about RS's for street etc, simply not worth it for the build here IMO, even for the street if there was enough cash simply because there is something (-5's) that will outperform the GT-RS's in everyway @ 370rwkw! Hell even 440rwkw if you were to get excited :banana:
https://www.sau.com.au/forums/topic/303739-which-camshafts/#findComment-5033171
in about a fortnight we will be doing a back to back test on std camshafts vs some 264 9.8's (both will have extensive dialling on the dyno to maximise area under the curve not peak), test car makes around 420-430kw so it may be of interest, then again it may not. I have no issue sharing the graphs.
https://www.sau.com.au/forums/topic/303739-which-camshafts/#findComment-5033248
Depends on the headwork as much as the cams.
One set might look nicer on a dyno, but how is it on the street (and vice versa). Transient response etc borders on impossible to see on a dyno, but you can feel it on the street etc etc.
Also being one item of head work might work well with stock cams, but another avenue works better with larger cams.
It's all so dependant on many variables that some back-to-backs are hard to draw concrete conclusions about for this stuff.
If your motor build/headwork respond to cams, then cams it is. If your motor build/headwork dont respond to cams due to the nature of the headwork, then no cams it is :banana:
https://www.sau.com.au/forums/topic/303739-which-camshafts/#findComment-5033260
true and everything should be taken as only informative not definative as with everything engine related, but it gives a solid idea as to where the curve shifts with just a simple cam change on this particular setup.
Depending on dyno you can actually do a drive cycle through each gear (timed and loaded the same as the street) and look at the effect lower gears (lower/shorter load) have on the afr's. We looked at one of the race logs from PI and matched the time in gear so we could "better" replicate the added loads of aero drag etc
You can also set it up a cruise load then nail it (in any chosen gear) and launch into a loaded pull, this allows better tuning of said transients... not perfect but damn close.
Would love to see your car on the dyno one day Ash, you can even provide a operator if you wish, would be good to set a known comparo for all the guys on here that dont seem to get the gtss's working right (ive heard your is very well setup).
https://www.sau.com.au/forums/topic/303739-which-camshafts/#findComment-5033274
Oh ye... if its a stock head - very good comparo being most heads would be near enough to identical :banana:
Ye i'm still coming past - WHEN i get the car back. Severe delays with Nissan & parts not arriving (joy of owning a HR31 & certain parts i just cant use GTR parts for lol), its just gathering dust atm so i will 100% call in.
But its sadly going to be a few more weeks yet. But i'll be in touch. I'll do Racepace, you, Drifty all in a day if i can wangle it just for interests sake :P
https://www.sau.com.au/forums/topic/303739-which-camshafts/#findComment-5033282
    • Maf is a question mark but TPS  I have set at 0.47, the fact that I’m getting proper voltage range out of it with the key on leads me to believe it’s functioning properly. I’m getting proper voltages on basically everything. I still need to look up voltage ranges for z32 maf and test that
    • Honestly no not at all, but it’s a very basic tune, it’s stock injectors q45 tps and z32 maf. Other than that it’s a completely stock base map. The file is from nistune and from my understanding if it was tune related I would be able to unplug maf and tps and it would still start even if it was a really shitty start. I have tried starting it with coolant temp, maf, and tps unplugged none of those 3 togethor or individually changes anything
    • 🏆 Skyline Supremacy Meets Mount Panorama Magic 🏆 Join SAU NSW as we take the long way to Bathurst, the home of GTR greatness. Saturday 30th August 2025 7:00AM Meeting Hanna Park North Richmond 7:30AM Departure Cruise Via Bells of Line Road 9:00AM Arrival to Stop 1: Golden Poplars Meadow Flat 9:45AM Arrival to Final Destination: Mount Panorama Motor Racing Circuit Meet Location: Hanna Park North Richmond Stop 1: Golden Poplars Meadow Flat Final Destination: Mount Panorama Motor Racing Circuit   *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • What does it look like with highway driving? And yes, I had a similar thought as Duncan. It looks quite similar in my Stagea and I have made myself accept it as normal. Might have to look into it some day   Highway gets as low as 10l/100km on my end so I'm not as worried about it being a mechanical issue. More likely just the tune on the haltech.
    • While I was waiting for the new parts to come in for the charge pipe and radiator I decided to do some turbo modification. The drive pressure (exhaust backpressure) was a lot higher that I thought it should be. For 32lbs of boost drive was 55lbs. The turbine housing is a 1.10AR and my turbo builder has suggested to go to a 1.25AR. To test if a larger AR would do anything to reduce drive pressure AND not spend any money I decided to hog out the divider in my current housing. I removed it from the inlet and the whole way through the housing.  After reassembly and testing it doesn't look like this modification did anything for reducing drive pressure or requiring more fuel (making more power). Oh well, it was worth a shot. We'll get some data at the track if it makes it past the 60ft. I also machined a $7 shift knob off Amazon to fit my Stillway shifter since I didn't like the Stillway shift knob. Next on the list was the radiator replacement and fabrication of a new intercooler tube that had no silicon coupler. No pictures of this - I was short on time each night after work to get this done and didn't stop to take pictures.  Next was to get the clutch disks out and replaced. Previously when installing the dogbox I had ordered a set of the same sintered iron disks I had been running because I switched to the 26-spline input shaft. I thought it was odd that they didn't have any markings or brand name on them like all my old disks had but installed them anyway. At the track I could not get the clutch to lock up using my normal strategies. After two track nights I reached out to the clutch manufacturer and ask their thoughts. They said they had to switch the material out because they were having trouble getting the original material and that this new material would not take to being slipped very well.  So out with the first set of 26-spline disks and in with the correct material 26-spline disks. While I had the trans out I added an inspection/service hole. I've wanted one of these for a while. Now I can have a look at things and change the front cover shimming when needed (clutch wear). I hustled and got the clutch change done in a few hours on a Saturday. Hopped in the car and drove home. On the way home I did a 1-3 pull. When shifting from 2nd to 3rd the core plug in the back of the cylinder head popped out and dumped all the coolant. Thankfully I was only 30 seconds from home and coasted it there. Datalog showed nothing unusual and 2.5psi of coolant pressure. That plug has been in there since 1992 but I guess it worked its way out. Pulled the trans AGAIN and replaced the plug, JB welded it in, and made a brace. Also deleted the head drain I had added in during the bearing issue fiasco.  I am currently changing my boost control plumbing to make it cleaner. After that is done I'll make another attempt at getting past the 60.
