I recently got some custom plates for my R32 GTR , i tried bending the old bracket to fit this did not work , also didnt want to bend the ends or cut the ends of the number plate off to fit on the front as this looks untidy , i have limited mechanical knowledge and time but this is what i came up with !
Got some zenith 100 x 100, 90 degree steel brackets from bunnings hardware :D and drilled new holes in them , so the plate would fit flush to the front bar using the three existing mounting screws .
Cut some pieces of 2mm powdercoated plate the same size as the front plate and the rear plate with a grinder. Rivetted the 2mm plate to the brackets for strength and drill holes to mount plates in corners
Remove front bracket again (undo underside screws) , paint both steel plates , Do the same job with the rear but use existing mounting bolt holes as fixing points for big rivets (works great ) drill two new holes on the bottom of rear bracket depending on what size plate you have, i went for square rear , slim front .
Finally rivet custom plate onto steel backing plates to make them harder to thieve ! :P paint rivets black to make good !
Edited by blingtr
https://www.sau.com.au/forums/topic/303763-better-way-to-fit-number-plates-r32/
  • 4 weeks later...
  • 1 year later...
  • 4 weeks later...
I done my number plate bracket yeste , came out as a massive success, i thank you Mark for your tutorial :) the only thing i changed was i measured a marking on the L bracket then drilled holes all the same length so the number plates were flush with the bar rather then sticking out 1cm or so..
great tut :)
(Y)
thanks so much.
good tutorial but would've been a better idea to screw the # plate down rather then rivet it lol
As he said rivet them to make it harder for the plates to be stolen.
Good tutorial....definitely looks awesome!!! :thumbsup:
    • ..this is the current state of that port. I appreciate the info help (and the link to the Earls thing @Duncan). Though going by that it seems like 1/4 then BSP'ing it and using a bush may work. I don't know where I'd be remote mounting the pressure sender... to... exactly. I assume the idea here is that any vibration is taken up by the semiflexible/flexible hose itself instead of it leveraging against the block directly. I want to believe a stronger, steel bush/adapter would work, but I don't know if that is engineeringly sound or just wishful thinking given the stupendous implications of a leak/failure in this spot. What are the real world risks of dissimilar metals here? It's a 6061 Aluminum block, and I'm talking brass or steel or SS adapters/things.
    • And if you have to drill the oil block, then just drill it for 1/4" and tap it BSP and get a 1/8 to 1/4 BSP bush. The Nissan sender will go straight in and the bush will suit the newly tapped hole. And it will be real strong, to boot.
    • No it doesn't. It just needs an ezy-out to pull that broken bit of alloy out of the hole and presto chango - it will be back to being a 1/8" hole tapped NPT. as per @MBS206 recco. That would be for making what you had in alloy, in steel. If you wanted to do just that instead of remote mounting like @Duncan and I have been pushing. A steel fitting would be unbreakable (compared to that tragically skinny little alloy adapter). But remote mounting would almost certainly be 10x better. Small engineering shops abound all over the place. A lathe and 10 minutes of time = 2x six packs.
    • Ahh. Well the block damage is a problem, you really need to run a tap or thread chaser through it to see if the threads can be saved, but any chips are likely to be bottom end bound which is bad. Earls seem to have what you need if you want to stick with mounting direct on the block: https://rceperformance.com.au/parts/earls-straight-adapter-1-8-npt-male-to-1-8-bspt-female.html, but as I said above I'd recommend remote mounting the sender
    • I'm not quite understanding or I'm missing steps here, (I appreciate people are trying to inform my brain but I am of the dumb, especially today) - All I want to do is mount the male BSPT of the OEM sender into the system somewhere without it snapping the adapter via vibration. The Nissan sender has a male 1/8 BSPT output. The block has a (very destroyed) 1/8 NPT input. I'm not really sure how a lathe assists with that, and also don't know anybody with a lathe, nor specifically what I would want to buy. I'm not really sure how adding additional adapters creates a better, more leak proof resilient seal here.
