  • Replies 846
Posted Images
Remember guys, Monday is March the 1st. Deposits are due then, if you haven't paid or have proof of payment before this day it becomes a first come first serve basis. Who ever fronts up the cash, is in :rofl:
will wire through full payment of $225 on thursday
You can wire through $100 on Thursday if you wish, only the deposits are due at this stage. But yes, the $25 on the day, if possible, bring exact change, makes things run a lot quicker and as you can imagine, you'd rather be on track than tracking down loose change :rofl:
You can wire through $100 on Thursday if you wish, only the deposits are due at this stage. But yes, the $25 on the day, if possible, bring exact change, makes things run a lot quicker and as you can imagine, you'd rather be on track than tracking down loose change :P
if i gotta give the money to you then i will bring $25 in 5c pieces lol......just to piss you off :rofl:
nah i would rather wire the full $200 otherwise i will use the $$ up somehow....seems to happen quite a bit lol
First, you're an ass :P
Second, totally understand. I'll make sure Reuben passes on the appropriate info when he checks for receipt of payment :(
Member Number: 3856525
From Account: XXXXXXXX
Payment Amount : $100.00
Date for Payment: 24/2/2010
Reference : scandyflick track day
BSB : 105-192
Account No. : 028822340
Account Name: SAU:SA
BSB : 105-192
Cheers Dave, will confirm with Roo Roo once payment goes through :P
Congratulations to David (writeoff) for winning the track day raffle. He will now participate at the low cost of $5. Mind boggling as to why more tickets didnt sell, even to those who had already paid and/or entered, surely the $5 gamble is worth saving hundreds.
Again, Congrats David from the exec :devil:
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
