Hi Gson, you can get the air going through only a part of the core, regardless of where the inlet and outlet are. The better desinged end tanks stop this, or some fabricators fit a deflector in the inlet air stream to make sure all the core is used.
Hi markr34gtr, you will only notice the difference in response with a back to back test of the intercoolers. You would have to do this on the road, the dyno would be no help. The 2530's have such great response themselves, you may well be satisfied with what you end up with anyway.
Hope that helps
Interesting thing about theory and the real world.
You can make generalisations such as x type intercooler will have a larger pressure drop than y type intercooler.
In theory a tube and fin shoud have a higher pressure drop than a bar an plate, this is because the tubes extend past the end of the core (only slightly) which in turn means more turbulance (something you need in an intercooler to a degree, as it prevents skin effect), but better cooling.
Then all the variables come along such as core size, end tank design (much overlooked as sydneykid pointed out) and even the number of turbulators inside the tube or bar - these prevent skin effect. Too many and your cooler has too large a pressure drop to work well, too few and it wont cool efficiently.
What I am getting at is, I have seen some very good bar and plate coolers, and some very good tube and fin coolers - I have also seen poor example of both.
I think the trick is to get the right combination of airflow, cooling and pressure drop to suit your application - whether it be bar and plate or tube and fin
And remeber, if you spend a bit more on a good cooler, you get a good product, if you spend less and save a few hundred dollars you may find you are only wasting money. I have seen one guy on this forum who got a custom made cooler, the core size was right, they seemed to know what they were doing. He then tried a Jap cooler, and low and behold, fried his clutch.
I strongly agree with Ronin 09, if it looks too good to be true....
Did anyone notice (on the www.are.com.au page) the custom oil coolers designed for the R33 GTS-T in place of the grill?
I wonder how badly that would effect the radiator cooling as by the time you put a fmic in the only real way that a radiator can be cooled is thru the grill.
Looks guite snazzy anyhow...
Ok, now you guys are really confusing me.... I wanna put a FMIC on my R32 GTS-t... I wanna get to about 200rwkw so i don't need a top of the line super dooper cooler.... i was simply wondering if a GTR cooler will do the trick.... or would i be better with an aftermarket?... what do i look for in a cooler?... cheers.
DJ984, a GTR cooler will be fine for your application - they will flow up to 300rwkW happily. Hope that simply answers your question.
Money wise, you will have to make the decision whether a second hand $600 GTR cooler vs a new (say) $700 cooler (remembering that you will have to pipe both to fit the GTS-t) is worth it - would you want to spend $100 more for a new cooler?
But yeah, a GTR cooler will be fine for your application.
Another thought...
How about the new Hybrid intercoolers that are starting to appear around the place?
I bought one of the 600x300x75 hybrid bar/plate and fin supercoolers through e-bay and its surpost to surport up to 800hp with a 0.5psi drop, im running it with the rb20det from a r32 and have had nothing but good things said, as yet i havent driven the car with it cooling the air but will be running 12 psi for now and am just waiting for the pipe work to be finished.
all up for $1100 fitted custom piping thats not a bad deal!
For the extra $100, I'd rather get a brand new cooler. A GTR cooler might be up to 10 years old and have pinhole leaks, or headed towards getting some. Although if you could get a good deal on a near-new '97 GTR cooler, maybe that'd be ok.
    • Yes, I know🙄 but the sequential is not in my budget... don't want to reduce power neither, so looks like I'm stuck in the rabbit hole🤣
    • You’ll be very upset when you bust that too not to mention the gearing totally sucks. Don’t do it.
    • Is the panel filter one that is oiled? Have you ever cleaned or touched the AFM?
    • So.... the K&N air box thingo was too big, ended up gifting it to a mate, well, by gifting it he actually supplied food and beer at the pub,  which was nice, as it will not sit on a shelf in the garage for the next 10 years I did trim up some of the existing stuff to neaten it all up and gave it some wrinkle paint, unfortunately it currently has a used and abused mish mash of different types of hose clamps, 4 big fat T bolt type (shit), and a few normal clamps of vairing sizes and brands, but..... only until the 6 constant tension black worm clamps that I ordered from EFI solutions turn up next week Currently the current hose clamps are triggering me hard, LOL Is this the final version, probably not, I really want just 2 silicone pieces, a straight bit of silicone from the filter to the MAF is easy and will happen as soon as I head into Just Jap tomorrow, the problematic part is a 30° silicone bend from the MAF to the TB that I can connect the engine breather from the head, I found that there are bulk head fittings for boat bilge pumps that should work, but until I can get a 30° silicone bend the alloy pipe, and the 11ty thousand hose clamps, are there for the foreseeable future 4 hose clamps are golden, 6 are grudgingly acceptable, the 8 currently holding it all together is just taking the piss    I've also ordered 60 more retaining wall blocks for the front yard, I mis-gonculated the height that was required to get above the base of the Photinia's (red robin's) that are the hedge behind the front fence, currently it is 2 blocks high, and about 1/2 a block short, so going 3 blocks high will be above the base of the red robin's, and allow some room for mulch
