  • Replies 57
i still prefer the miata in the drift. i am doing 80,000 point combos. entire laps. its awesome.
Your not wrong about that...i just went for a spin in the MX5 miata and its mad. Did a 50,000 combo just like that. Damn and i though the RX7 was good...i think ill be drifting the Miata from now on.
i know this is a little of topic but what controller's do u use for drifting and getting high point's.
keyboard, steering wheel?
i recently bought a psx joypad converter and it is a 5hit load better then the keyboard to drift and race ,especially when the time comes to drag and your can't hold the revs in that right spot to get a good launch..psx controller make's such a hugh difference and can drive the cars alot harder..
Im just using the keyboard, but im sure a controller would be WAY better...to controll the throttle better during drift...im just managing with the keyboard at the min
Where u get u r controller coverter from...i wouldnt mind one
Yo, I woke up today, i thought that some day I should get an X-Box... SO I got out of bed and went to Myer and bought that beast pack...
I had 1 hour before work, I thought I'd take it to work and you know what? I went and got NFS Underground thinking the TV at work would have RCA inputs...
Friggin cheap TV... have to wait 14 hours now until I get home....
But when I get started... Imma thrash your records hahahahaha (evil laugh)
Chill
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
