hi guys dont suppose anyone knows where I can buy some sheet alloy, ive looked up a few places but they only sell really big sheets, I just need some to make a floor for the boot so I dont need a huge amount, and im not sure what type I need obviously its not dealing with heat or anything.
cheers - Alex
Edited by s13_Skyline_inside
https://www.sau.com.au/forums/topic/304130-where-to-buy-sheet-aluminium/
Just search for madalia steel places next to where you live the standard size is 1200*2400 id use 2mm they are around $120 or you could order a sheet in that it smaller and that would be 1200*1800
Edited by ACTIV32
If you dont need alot hit up bunnings....they sometimes stock Sheets there...
I bought Some a few months ago.... 900x900 1.5mm thick for 32ish bucks a sheet
They have thicker but not sure on price...
give it a shot
will it be taking any weight? if you use your boot then you would need atleast 3mm thick alloy.
your best bet normally is not to go to a supplier for smaller portions, but to a sheetmetal shop and get them to supply
we do sheetmetal in my shop also, so with a template we can cutout what you need (after tuesday due to the long weekend though)
    • HELP   Hey all, Is there an accelerator cable from another Nissan that can be used on the R33 GTST RB25DET with a Greddy forward facing plenum?  Thanks in advance  Rob
    • Or do we think it was installed to give 1 bar of boost max, all day, everyday?
    • So could it be assumed it has been installed intentionally with potentially a power FC boost controller kit?
    • Had my rig on Matt's dyno at PITS the other day. After a few years between tunes I added a few sensors and swapped intercoolers. Result. 553hp at 26psi. Not bad for an FJ20 that was built in 2007. The problem.. It filled the overflow bottle on hard runs which leads me to believe the head gasket isn't sealing. I have a coolant pressure sensor which was reading cap pressure at 22psi and occasionally overrunning to 23/24 psi on deceleration after a pull. It was not spiking. It has arp2000 head studs and a cometic gasket. As its been 18 years in service, I pulled the engine out and head off. Everything looks good but we obviously have an issue. Where I'm at.. Years ago I had the same issue, I checked the stud tension and they were all over the place. Some at 60 to 70 and some up near 90. I nipped them all to 100ft lbs and this stopped the water push until now. I believe this compromised the gasket back then. What do I do? 2 options are..  1) I bought arp 625+s, which I could put in with a new gasket. Thinking Kameari this time, reassemble and try again. 2) strip the block, get fire rings machined in with copper gasket and try that. I do not want to push it more than 28 to 30psi. I think the turbo will be out by then anyway. (G30-770). My other concern is the long term ability of a copper head gasket. Are they streetable for years? I feel like a new gasket with the new studs will probably suffice, but I don't know. Any thoughts welcome and advice on copper gaskets and fire rings. Thanks!
    • I'm a fan of the JZX110, and the Aristo. Big cruiser cars, and with the factory cars, super comfortable and feel like you're driving an armchair! And the JZ motors are a pretty nice engine too, especially with some basic mods.   The import process, and the need to be able to trust people, and the fact there's so many scammers around is what ever puts me off wanting to go through that ordeal!
