I have for sale a KTS 7 Point Rollcage.
This will fit both 2 door and 4 door R32 Skylines.
It is unassembled at the moment as I haven't got around to putting it into my car.
Will sell for $750ono.
Comes with all bolts and base plates.
Pick up preferred. Item on sunshine coast.
PM me or post on topic.
Kails
Pics pls
what sort of fit is it? After something that's a snug fit
Will get you a pic tomorrow it is unassembled though at the moment.
It is a great fit the front hoops go around the dash.
kails
Pics pls
usually bolt ins are quite tight around the interior trims, sometimes you even have to remove the headliner light. and with the hoops they come real close to your head light switch and if its padded you got no hope. also full cage arnt street legal i believe. and you most likely wouldn't be able to fit the sun visors, but dont take my word for the could be wrong.
GL with sale kails.
GL with sale kails.
full cages are legal, but need an engineer to go over the car and to be mod plated.
This cage is legal as it is bolt in, although i have been told that the front brace that goes across the windscreen is not legal as it obstructs the drivers vision, (go figure when a rear vision mirror hangs lower :ph34r:). It is a very tight fit and yes the car it came out of no longer had sun visors which again is a legal issue with getting it mod plated, but as I said as long as the front brace that goes across the front of the windscreen isn't in when you get it mod plated then it shouldn't be an issue. This is what I have been told anyway.
Edited by kails
not sure if u got my reply pm
please pm me a contact number if possible
thanks
Hey team carefactor,
Yea i received your pm sorry I didn't reply have been a bit lazy atm with that side of things. I have decided I will keep the cage for the price it will cost me to replace it with one it's not worth so cheers anyways.
UPDATE TO EVERYONE:
CAGE IS NO LONGER FOR SALE HAVE DECIDED TO KEEP IT :laugh:
Kails
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
