Hey guys, I've been given a R34 GT-T ECU thats been reflashed/tuned by Dr Drift, could I plug this into my R33 S2 GTS25T? I'm guessing it's not going to be plug and play, I didn't achieve much out of searching. has anyone done anything like this before? I've also been given Splitfire coilpacks for a R34, bigger fuel pump and bigger injectors. a quick search tells me the coilpacks will fit a S2 R33, but the injectors won't without modification. Help is much appreciated, cheers.
Rover.
https://www.sau.com.au/forums/topic/304233-r34-retuned-ecu-into-r33-s2/
The R34 ecu has a diffrent pinout/plug to an r33, so unless you use the r34 loom aswell it won't work. Or splice the r34 loom plug into your r33 loom. But either option would be quite a big job. What is the ecu tuned for? I.e what mods etc was the r34 running? Would be interested in buying it off you if you decided it was too much work to make fit. Hope this helps you.
The R33 S2 and the Neo version coil packs have the same plug however the Neo coil pack has 2 mounting bolt holes and will not bolt on to the R33 coil pack rail as spacing is different.
The S2 coil pack has 3 mounting bolt holes.
So the Neo coil packs should work in the R33 if it comes with its rail.... providing the entire rail will bolt on to the R33 head.
the ECU came out of a 34 that had splitfires, blitz ebc, fuel pump, injectors, bigger turbo and fmic. Currently tuned to 270rwkw. All belongs to 'hamoti' on here who wrote it off a few years back. I'll have a chat to sam from dr drift tommorow. Cheers.
Neo coils bolt directly to the head, no rail. They are also all facing the same way and the spark plug is in the center. I know some guys here that will just sit the coil on top of the plug with nothing holding it down because Neo packs are hard to find.
As for this ECU swap, it will be very hard to get it right. The VCT solenoid works differently in the Neo than the R33. Also, the Neo has more vacuum switches to run emitions stuff that isnt on the 33 motor. It will be a big pain to switch over ECU plugs as well. Just save yourself the trouble and get a Z32 ECU if you want to Rom tune.
Spoke to Sam today, 34 ECU into R33 is too much trouble. And a flash tune on the stock 33 isn't worth it. Instead he suggested an R32 ECU + VCT controller, quoted me $1000 everything supplied, fitted and tuned. Sam also told me the Z32 ECU is an option but they're not quite right with idle and a few other things... He also gave me the option of GTR cams with cam gears for the VCT dilemma, but highly recommends an R32 ECU + VCT controller. Anyone have any other suggestions? I read Rising Sun on here can retune R33 ECU's, need more info though.
Cheers.
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
    • I checked spark on all cylinders and they all visually have spark with the plug pulled and grounded, but plug 1 is the only one that fouled. This was a running swap that blew up and was rebuilt by a machine shop, put a new wiring specialties harness and did all gaskets, studs, and bolts while it was out.  compression is 135-150 across all cylinders. Aside from that from my understanding with the z32 ecu and maf the car should start regardless. The wiring for TPS and the dual 02 sensor/ dual knock sensor stuff shouldn’t actually stop the car from starting or even running well, (just slightly rich)  they just give fault codes. Car supposedly is supposed to start as long as you have z32 afm and ecu with the nistune base map and that’s info coming from a well known and trusted tuner who does a lot with SR/RB (Rsenthalpy). After more trouble shooting today where I’m at right now is that the cas is sending signal to the injectors they click while spinning the rotor, Fuel pressure is now set at 43psi, all cylinders have good compression and all of the plugs looked great (just wet with fuel) except for cylinder 1 which was very black (cylinder 1 has 150psi compression). all of the coils generate spark if pulled out and grounded out on the head. On the fuel pump car just pops into the exhaust. On starting fluid car will fire off. Hard to tell if all cylinders are firing off but definitley a couple. sounds like all of them but it’s only for 3-5 seconds hard to tell.
    • Final update!!! Got the front bar fitted and sprayed and all sorted now. My cutouts worked great and the indicators aren’t just falling off. 😂
