does anyone know what i have done :P ?
or had the same or similar experience
how to fix it or replace it ?
any help would be appreciated
Thanks Nick
Probally leaking from heater box, pull it out and see if u can fix or prob get a new one.
i would take apart the dash and have a good look
+ what's the condition of your radiator like? If you don't want to go to the effort of taking heater core out you can always try to use some radiator stop leak in there first depending on whether it's a pinhole or whether it's a split/corroded seam. If it's the latter only a new core will solve the problem.
yep heater core, looks like this once removed:
the 2 yellow pipes attach on one side and stick through the firewall into the engine bay (and onto the motor via heater hoses)
whole dash needs to come out to change it unfortunately.. or if your aircon isn't gassed up you might be able to do it via the glovebox area
how do you know if the aircon is gased up ?
what happens if you disconnected it with it gased ?
Well does your aircon work or not? :bomb_ie:
If it does - then it has gas in there.
If it doesn't - well, there is no gas :)
    • I like their veal scallopini.
    • Definitely a hearty eater when we go out, I consider these meals my cheat day as I've been watching my calories in and calories out pretty hard since my little fun size stroke, I've gone from a fat boy of 89 Kg, I'm only 165cm tall/short, down to a almost semi lean 73 Kg over the last few years, I'm currently around 17% body fat which my doctor is very happy with, but, my goal is to slowly get down to and maintain 15%,so yeah, I want all of the protein, carbs, fats and sugars when I go out for a binge
    • There was a great one on Victoria Rd in Gladesville too back in the day. I can only assume GTSBoy is thinking of the mill up on the wollondilly, no restaurant there any more but they have restored the original steam engine on site and run it every few months, have an annual steampunk festival etc @The Bogan, you came to the wrong town for restaurants. we have a few reasonable asian and indian options but the Paragon is as good as it gets otherwise. That brewery is apparently just opened, been meaning to give it a go some time. The Highlands have plenty of fancy options but I suspect you are more a hearty eater than fancy eater
    • Thanks for coming back to post the update, maybe it will help out the next person!
    • Going by the intake & injectors I'd be guessing it's a DE, check the head casting number, should be 5L8 on a DET, 5L7 I think is the DE number.
