Basically searching for after market injectors for RB25 NEO is proving difficult, and the results I do find are expensive.
I've heard that injectors to suit WRX STI will also suit RB25 NEO, and they're not difficult to find at all and are also cheaper (from what I've found)
So want to clarify that they will indeed fit before I go ahead and purchase anything.
What's your reason for bigger injectors?
I also have heard that STI injectors appeared to be a fit, as they physically look the same, you have to get more details on the injectors like the impedeance. XR6 injectors are also supposed to he a fit, the only problem being the length of the injector, as spacers are needed to adapt to the neo fuel rail.
Have you looked into the seimens injecotr that are going around, you can get them with an electrical plug kit and a spacer kit so all you have to do it fit the injectors and change the plugs. These are cheap as well, I've seen them from between $500-$600 for the kits.
I'm running a set of 600cc deatchwerks injectors, they are a different shaped body to the stock injectors but a direct fit, electrical plugs are the same too. They are an American company but the service is excellant, I got mine for $600 delivered (the exchange rate was really good when I got them).
Deatschwerks are a good company to deal with. Was there an issue with the injectors sealing properly with the different body size?
If they go straight in that is another good option since fiddling around with plugs and spacers will usually cost you in labour negating any savings.
I had no issue with them sealing properly, even though they where a slightly different shape body, they where no wider than the stock ones, and the inlet and nozzel seals was the same size as the stock ones, it was a very straight forward swap. one thing I just remembered was they where slightly longer, about 2.5mm, so I had to space the fuel rail off with a couple of washers at the two mounting points. No big deal though.
Yes, I got a flow test sheet of all the injectors, both at a controled injection and static injection. I can't remember off the top of my head but they where matched to each other with a very low variance, I'll check when I get home if anyone is interested. And as you said, came with new o rings and little tube of o-ring lube to use when installing.
"XR6 injectors are also supposed to he a fit".
Referring to Josh's comment, I've used xr6 injectors on an rb30, cant comment on rb25.
But Nissan being Nissan, things will be similar/same.
My mate had to trim a bit of plastic of the top of the injector where the fuel rail pushes on but all was good.
I think upgrading to larger injectors is due to the fact alot of people want to eventully pull more power out the car, thus needing larger coilpacks or chancing your odds with the stock ones.
Anyone thought about just getting the stock injectors redrilled?, Thats what i am
going to do when i get a stagea , pretty common these days
cheers
darren
re-drilled?!? :D lol i hope you mean hi-flowed, which is also an ok option, but at around $100-$150 per injector, it comes to around the same price if not more than a brand new set of something like the Siemens DEKA ones or even Deatschwerks (depending on exchange rate).
a couple of the downsides IMO to hi-flowing are:
- even though its only when you get them, your car is off the road while they are off getting hi-flowed. for people that rely on there stagea as a daily, this is no good.
- unless the hi-flowing process involves replacing the solenoid/actuator, you still have a ~10 year old injector.
Edited by QWK32
Great feedback people. Thanks.
At this point thinking Deatschwerks... But I'll continue looking.
P.S. Yes, I'm looking at larger injectors to pull bigger figures. Next performance upgrade will be turbo and injectors.
im at 85-86% on the stock injectors running only about 10psi
looks like they are smaller than det injectors maybe, thoughts?
85% at peak flow on stock ecu and 10psi sounds right. Keep in mind that once on boost the stock tune heads fast for 10:1 AFR's, get a tunable ecu or piggy back, take some fuel out, and you'll see that duty cycle drop.
10-4 good buddy, nisstune or bikirom maybe will be coming, just need more moneys :D
10-4 good buddy, nisstune or bikirom maybe will be coming, just need more moneys :blush:
R34 GTT Apexi PowerFC especially if RS4S!!! less tuning time and easy fit with secret squirrel!
Anyone want these Blitz neo 525cc $600ono
meh, $1500 for power fc + tuning or ~$1500 for a tuned biki/nisstune
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
    • BTW I measured the jack I have, it is 70mm at the saddle but you only have about 700 until it returns to 150mm high at the cylinder so it is good but no magic bullet.
    • My experience with Rising Sun Exports Before agreeing to the sale I tried to do as much research as I could (obviously), his Facebook reviews are 98% and he goes Live at least once or twice a week. I contacted 2 people in the UK who had used him for their imports, both had positive feedback. His explanation and talk through of the import process was thorough, answering any query no matter how stupid it was. It felt as soon as the money was sent, communication dropped off. I asked for shipping updates every 2 weeks or so, not wanting to pester him, he never had any updates. I wasn't informed the car had been dropped off at the port, I only found out by his Facebook story. I asked for the photos taken at the port, knowing he would need some for insurance purposes. I received a few 5 second clips and that's it. When asked again, he said his staff had them. Weeks later I asked again, he tells me he doesn't have any, but does have 50 photos from the original advert. I never received them. I eventually got the documents sent via WhatsApp after I mentioned the port was requesting them. I purchased a CarVX report, to find out the vehicle is a Grade R with recorded accident damage, first recorded in 2017 when it was first auctioned. He never told me the grade, then again I didn't ask. His response was "Grade R means nothing, it wasn't chassis damage". Still, I would have liked to have been informed about it. Jon prides himself on being open and honest when it comes to inspecting cars, it's his main job doing so at the auctions for customers. When the vehicle arrived in the UK I noticed a few little cosmetic issues. It's a 21 year old car so it wasn't going to be mint condition. The side skirts are cracked on each corner and the sealant is failing. The front grill on the bonnet/hood isn't secured very well, mounting studs are missing. Both minor things, but again, it would have been nice to be told. During a Facebook Live walk around video of the vehicle, he mentioned it has a front Whiteline anti roll bar/sway bar. While on the inspection ramp, I noticed the stock item has been installed. When first questioned, his response was "the ARB? Switched? Since when, it never had them". Since sending video and photo evidence I've not received a response. I'm probably being over critical of the overall condition of an old car, but all I wanted was honesty (which he claims to have). I'm aware I wasn't his only customer, he's busy doing XYZ but other reviews praise him for great communication with regular updates and photos, I felt I didn't receive the same treatment.
    • I was able to get some underside photos while the car was on the ramp The suspension is all Altezza/IS200/IS300 so getting part's will hopefully be less of a headache
    • Welcome to my 2004 Toyota Mark ii IR-V Fortuna (series 2) With a 1JZ-GTE powerplant under the bonnet (hood) it'll give me plenty of scope for power upgrades. For those who aren't familiar with imports, the 1JZ-GTE is a 2.5L 6 cylinder VVTi engine with a single turbocharger. This has the factory R154 5 speed gearbox, along with a aftermarket 2 way LSD differential (brand unknown). Under the arches are a set of CST Zero 1 alloys, 18x9 +30 225/40 up front and 18x9.5 +15 265/35 on the rear. The car was quite low in Japan and there's evidence of the wheels catching the rolled arches/fenders. The tyre's aren't great so I'm in two minds whether to replace both or just the tyres and put up with the wider wheels on the rear. The car still uses stock brakes with the addition of some braided hoses. The exterior is stock with the exception of a BN Sports front bumper and a replacement Fortuna grill  Moving to the interior, the steering wheel has been replaced with a dished MOMO steering wheel (which will get swapped for my Momo Tuner for the time being) Defi Link Gauges are mounted above the climate controls and on the A pillar, the Oil Temp,Oil Pressure,Water Temp and Boost gauges should help with spirited and track driving  The stock seats have been replaced with some retrimmed Recaro bucket seats. Being a larger build these are a little snug, unfortunately the orange isn't for me so I'll look into replacing these down the line. Other modifications include a twin plate clutch, Blitz intercooler, Evolve alloy radiator, a stainless exhaust with decat, HKS EVC-S boost controller and coil overs
