spark plugs...
Guest Boxhead
hey guys, my grandfather gave me the hint that it woudl be cheaper to clean my platintum plugs then replace them, but... you see, i dont know where or how to get to them, my grand father used to be a mechanic, but retired some 20yrs ago, he knows how to clean them, but has no idea how to get to them on my rb20de.. can someone help me out? pics woudl help alot too.. thanks guys
https://www.sau.com.au/forums/topic/3047-spark-plugs/
I found them under that panel on top of the engine too, but the panel is a biatch to get off without taking all the stuff above it off first. I basically unscrewed it but couldn't get the panel out because of everything else in the way.
Is there a quick way to get at the plugs or do I really have to take all the plenum hoses and stuff off first? This is going to be a big job just to *check* the condition of my plugs.
https://www.sau.com.au/forums/topic/3047-spark-plugs/#findComment-53083
Only takes about 30 mins to take everything off, change the plugs and put it all back together again.
I did mine recently. Pretty easy really.
Disconnect the BOV from the return hose, losen off the hose clamps and take off the intake pipe that goes over the top, from memory you have to take off a couple of other hoses as well but it is nothing tricky, just remember where it came from and put it back there after.
Then you have a few bolts to get the black panel out. Under that you have the coil packs, they should be on brackets in groups of three. Disconnect the cables going to them and pull the, out, be careful with then as I have heard that they are fragile.
and hey presto there's your plugs!!
Give the intake pipe and the rocker covers a quick clean and polish while you have it all in pieces, only takes a few minutes.
https://www.sau.com.au/forums/topic/3047-spark-plugs/#findComment-54318
I had major problems with spark plugs not so long ago so i consider myself an expert at getting to the suckers.
I am able to get everything off and plugs out in around 15mins.
It really is easy.
Don't stuff around trying to get around the cross-over intake piping just undo the clamp pull off a couple of vacuum hoses undo the bov return pipe rubber hose clamp and fling the intake piping to 90degree's then undo the Ignitor thingo majig (black square thing at the back of the motor) and then use an allen key to take the plate off.
No skinned knuckles like the other VS V8 I had.
I prefer to do the plugs on this motor than all of the other cars I have owned.
250 TE 4 Speed Cortina
VL 3ltr 5 Speed Commodore
VS V8 5 Speed Commodore
It really is very easy. Grab a cold bear and start to pull things off with the radio going :D
30mins max :( In and out.
https://www.sau.com.au/forums/topic/3047-spark-plugs/#findComment-60154
Originally posted by Boxhead
ill give it a go when i get the car back, thanks for your help guys... if i get stuck i will come back on here.. but i shouldnt...
joel, when are you coming to the gold coast next? i will see if i can put myn off till then haha and you can show me how to do it.
If you want to drive it to Brisbane I will help you out and show you how to do it.
https://www.sau.com.au/forums/topic/3047-spark-plugs/#findComment-60572
  • 4 months later...
Guest RedLineGTR
Just when you disconnect the cables, the coil packs are on the metal brackets bolted on, do you unscrew the bolts of the brakets or the screws on the coil packs???
And do you just pull them off the plugs or what?
Thanks
https://www.sau.com.au/forums/topic/3047-spark-plugs/#findComment-140023
RedLineGTR, the coilpacks are held in by small bolts. There are 4 holes on each mounting bracket, but mine were only held on by 2 bolts each. I don't know if this is like that from the factory or if the previous owner CBF'd putting all 4 back in. Two on thediagonally opposite corners is more than enough anyway.
Once the bolts are out, gently pull the coil pack up and off the plug. It's held on by a rubber moulding similar to what holds normal leads on plugs. You should probably unplug the wire from it before doing this, but in the interests of minimising the amout of stuff removed I left each coil pack hang there off the wire, doing one at a time.
https://www.sau.com.au/forums/topic/3047-spark-plugs/#findComment-140778
    • Had another look at the car and I noticed the fuel pump isn't priming on ignition. I'd taken out the pump from the boot to siphon out the old fuel, so maybe I've knocked something loose or broken a wire putting things back together. Will go back with a multimeter and try to work out what's stuffed. Kinda hoping it's the pump itself thats gone so I can upgrade it
    • Yeah agreed, you can't assume that shop are they only people who ever had to work on it. It was just a guess on the mods based on how things were done back then. You can check the Air Flow Meters by the part number on their tags, they are likely either Z32 or Nismo ones (both read about the same but the Z32 one is a little larger while nismo is stock size but supports the higher airflow like a Z32). And yes, all that would get you to 450hp / 340kw To tell what is happening with the turbos, you want a photo of the tag on the core, that will say what it was made out of  (they can retain the front and rear covers to make the plumbing easier)
    • I'm selling my personal race car. 1992 BNR32 Skyline GT-R About eight years ago the engine developed the dreaded low oil pressure problem. I removed it and found the issue. However shortly after I moved half way across the country, moved my work shop, bought a house, got married, then moved my shop again to it's permanent location for the time being. in turn I do not have the time to race this car as it should be. In turn the engine I built for this car will end up in my street car and this car I hope finds a home with someone who can use it to it's full potential. The roll bar was built by Jason Noren Fabricaiton in Pomona California to SCCA and NASA Specs. The car used to compete in redline time attack and global time attack enthusiast class. It also has a fire suppression system.  The car is with me at my workshop in Kyle Texas, USA. Shipping it is no problem, I can personally deliver the car to the port of either Houston or Los Angeles. Any other port depending on where it is may require transport but we can always work that out.   The chassis itself is rust free, rear quarters and under fenders are free of any rust so it's a very solid foundation for anyone who wishes to move forward with it. As posted and at the asking price of $20,000 USD the car includes all of the following;   All OEM Body panels, front fenders, rear bumpers etc.  OEM Nissan Projector headlamps (Pictured N1 lamps were removed) OEM Nismo Side Skirts / Extensions OEM Rear Spats  Front & Rear Subframes are installed car is full roller Rear Subframe has Cusco Camber Arms, Whiteline HICAS Elimination Front Subframe has Whiteline tension rods and whiteline Sway bars w/ endlinks.  Buddy Club N1 Coilovers All chassis wiring and engine wiring is in tact. Attessa System is fully in tact and was functional before engine removal.  BCNR33 GT-R Brembo Brakes F+R with Endless MX72 Plus Pads, DBA Rotors & Stainless Steel Brake lines Billion Racing Radiator Billion Radiator Hoses Fluidyne Engine Oil Cooler Accusump System (trunk Mounted) 5 Speed Transmission w/ Transfer Case F+R Prop-shafts Rear Differential With rear Axles.  Nismo Gauge Cluster Nismo Clutch + Flywheel   Essentially what is needed to make this car running and driving again is as follows: A working Engine, an ECU, and time to put it together. The price posted is or best offer as I am willing to remove some components to accommodate price to a certain extent. If any serious buyer wants full detailed pictures, videos, or any questions I'll be happy to answer them. I believe this car is priced to move quickly considering it's a rust free and very straight chassis but always open to fair negotiation.  I can be contacted via phone or email. (+19517081648) email is [email protected]
    • So...to my (and my mechanics doing the swap) surprise...the oil pan from NEO engine does not fit 100% and needs to by modified like this: It is not a huge problem but in the future i want a "proper" oil pan. So question is...what different oil pan can i get to fit without any problems and modification? Thanks!
    • Some more info I found.  These are the last entries Yoshikiyo Fujii made on his blog before he passed away in 2009: http://blog.livedoor.jp/fujii_dynamics/ And finally this is where the workshop was situated:  https://maps.app.goo.gl/HhTPtHzt3WVcBTiEA
