Hi,
I thought there was a sticky on spark plugs but I can't find it, I've searched and found a few threads.
Its also an interesting debate in regard to going Copper and replacing every 10K or going Platinum/Iridium.
Any advice?
Finally, which one should I be using?
A BCPR7s/BKR7s ?
R33 GTR, standard tubo's, 1 bar boost, not driven too often if that makes a difference :D
Thanks,
Gareth
EDIT: Also is Repco a good place to buy spark plugs?
I noticed that performancelub has fairly cheap Iridium/Platinum plugs
300rwkw daily driven
i use bcpr7es @ 0.8
I'm only 250rwkw so I assume the bcpr6 might be a better choice. I'm unsure how to re-gap spark plugs so would prefer to buy the right size if possible :)
Ah bullshit you searched, i know you be telling furphies ;)
Just have a read of the Forced Induction Guide Gareth, its a sticky in Forced Induction.
It has a link to "what spark plug" or something similar, plenty of info for ya there :)
You wont need to gap the plugs. 1.0 - 1.1 willl be fine
i have been using 7's in my car all the way through, 150rwkw 185rwkw, 269rwkw, 285rwkw, 311rwkw and now 323rwkw
if you buy BCPR7ES or BCPR6ES they will both be fine..... and are already gapped @ 0,8
the BCPR7ES11 are gapped to 1.1
I would use 1 heat ranger cooler ie 7's on a stock engine with no mods and look at running 2 heat ranges cooler "8's" and smaller gap if you at pushing more boost ie about 1 bar.
Pending on condition of coils the larger gap may still work fine but due to age and condition every car is different.
http://www.skylinesaustralia.com/forums/Ng...eri-t68157.html
Ah bullshit you searched, i know you be telling furphies :)
It has a link to "what spark plug" or something similar, plenty of info for ya there :blush:
I read the general maintenance section, a quick check of the tutorials, and a search which brought up lots of debates about copper vs iridium.
Didn't think of the forced induction sticky :P
Besides you overrate search, I was searching for "spark plug" or similar, I didn't know what terms would bring back something useful :P
I'll just use BCPR7ES (-8 gap) then...thanks for the help (or 6ES if I can't get them).
Thanks everyone!
I think if there is no trailing dash and number (-8) then the sparkplugs are 1.1
ie. BCPR6E are 1.1 whereas BCPR6E-08 are 0.8
Ive been using BCPR6E's on my car, but ill be trying out 7's because ive noticed speckles on my sparkplugs which indicate that they are too hot.
BCPR6E are better than BCPR6ES. The 's' stands for standard tip whereas the other has a v-groove tip which they say is better.
Also, stick with coppers and change them every 10,000km.
im with hamish, ive got some BCPR7ES-11 rolling around the glove box of the daily. where as the BCPR7ES with nothing noted on the end are 0.8's.
by the by i run BCPR7ES and well under 250rwkw
my mistake, no dash number means default 0.8
Although according to their site they say 0.9
http://www.ngk.com/results_cross.asp?pid=BCPR6E
Projected Tip, JIS Height, .035" (0.9mm) Gap
More information on V-groove sparkplugs (BCPR6E no 's' at the end)
V-Power spark plugs are a patented design by NGK to improve ignitability and reduce quenching. Ignitability is improved by the V-groove cut in the center electrode parallel to the ground electrode, this directs the spark to to the edge of the center electrode thus exposing it to more of the air/fuel mixture. Quenching is reduced in much the same manner, drawing the spark to the edge of the center and ground electrodes reduces the surface area available to quench the spark. See quenching for more info.
i use NGK BKR7E in an RB26
does anyone else use these plugs
Looking on the website i posted above, the BKR7E feature the v-groove whereas the BCPR7ES does not. There doesnt seem to be a BCPR7E on their website so it looks like if you want the v-groove you need to get the BKR7E.
This assumption is all based off the ngk.com website though.
He had some kind of racing plug in there:
http://www.ninjapower.co.uk/product_info.p...-ngk-r67018-x-1 an NGK: R6701-8
Anyway, I've put the BCPR7ES in now, it was a little challenging but its done now, thanks for the advice everyone.
    • Maf is a question mark but TPS  I have set at 0.47, the fact that I’m getting proper voltage range out of it with the key on leads me to believe it’s functioning properly. I’m getting proper voltages on basically everything. I still need to look up voltage ranges for z32 maf and test that
    • Honestly no not at all, but it’s a very basic tune, it’s stock injectors q45 tps and z32 maf. Other than that it’s a completely stock base map. The file is from nistune and from my understanding if it was tune related I would be able to unplug maf and tps and it would still start even if it was a really shitty start. I have tried starting it with coolant temp, maf, and tps unplugged none of those 3 togethor or individually changes anything
    • 🏆 Skyline Supremacy Meets Mount Panorama Magic 🏆 Join SAU NSW as we take the long way to Bathurst, the home of GTR greatness. Saturday 30th August 2025 7:00AM Meeting Hanna Park North Richmond 7:30AM Departure Cruise Via Bells of Line Road 9:00AM Arrival to Stop 1: Golden Poplars Meadow Flat 9:45AM Arrival to Final Destination: Mount Panorama Motor Racing Circuit Meet Location: Hanna Park North Richmond Stop 1: Golden Poplars Meadow Flat Final Destination: Mount Panorama Motor Racing Circuit   *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • What does it look like with highway driving? And yes, I had a similar thought as Duncan. It looks quite similar in my Stagea and I have made myself accept it as normal. Might have to look into it some day   Highway gets as low as 10l/100km on my end so I'm not as worried about it being a mechanical issue. More likely just the tune on the haltech.
    • While I was waiting for the new parts to come in for the charge pipe and radiator I decided to do some turbo modification. The drive pressure (exhaust backpressure) was a lot higher that I thought it should be. For 32lbs of boost drive was 55lbs. The turbine housing is a 1.10AR and my turbo builder has suggested to go to a 1.25AR. To test if a larger AR would do anything to reduce drive pressure AND not spend any money I decided to hog out the divider in my current housing. I removed it from the inlet and the whole way through the housing.  After reassembly and testing it doesn't look like this modification did anything for reducing drive pressure or requiring more fuel (making more power). Oh well, it was worth a shot. We'll get some data at the track if it makes it past the 60ft. I also machined a $7 shift knob off Amazon to fit my Stillway shifter since I didn't like the Stillway shift knob. Next on the list was the radiator replacement and fabrication of a new intercooler tube that had no silicon coupler. No pictures of this - I was short on time each night after work to get this done and didn't stop to take pictures.  Next was to get the clutch disks out and replaced. Previously when installing the dogbox I had ordered a set of the same sintered iron disks I had been running because I switched to the 26-spline input shaft. I thought it was odd that they didn't have any markings or brand name on them like all my old disks had but installed them anyway. At the track I could not get the clutch to lock up using my normal strategies. After two track nights I reached out to the clutch manufacturer and ask their thoughts. They said they had to switch the material out because they were having trouble getting the original material and that this new material would not take to being slipped very well.  So out with the first set of 26-spline disks and in with the correct material 26-spline disks. While I had the trans out I added an inspection/service hole. I've wanted one of these for a while. Now I can have a look at things and change the front cover shimming when needed (clutch wear). I hustled and got the clutch change done in a few hours on a Saturday. Hopped in the car and drove home. On the way home I did a 1-3 pull. When shifting from 2nd to 3rd the core plug in the back of the cylinder head popped out and dumped all the coolant. Thankfully I was only 30 seconds from home and coasted it there. Datalog showed nothing unusual and 2.5psi of coolant pressure. That plug has been in there since 1992 but I guess it worked its way out. Pulled the trans AGAIN and replaced the plug, JB welded it in, and made a brace. Also deleted the head drain I had added in during the bearing issue fiasco.  I am currently changing my boost control plumbing to make it cleaner. After that is done I'll make another attempt at getting past the 60.
