Item: Chrome Car Badges + Acc.
Website: Nope
Item Condition: Brand new
Reason for Selling: Not Needed, bought bulk at auction only wanted some of them
Price and Payment Conditions: $PRICES AS MARKED
Extra Info: Buyer pays post, these have double sided tape already applied
Please Note - That if you require registered postage that is fine as postage is at buyers cost.
Pictures: Yeah
Contact Details: Pm.
1. HKS POWER BADGE (x5) - $5.00 Each
135mm W x 30mm H
2. TRD BADGE (x9) - $5.00 Each
150mm W x 30mm H
3. NISMO BADGE (RED DOT) (x5) - $5.00 Each
140mm W x 30mm H
4. DECEPTICON BADGE (x1) - $5.00 Each
80mm W x 90mm H
5. PLAYBOY BADGE (x8) - $5.00 Each
45mm W x 80mm H
6. PRETTY GIRL BADGE (x1) - $5.00 Each
90mm W x 65mm H
7. CHEV BADGE (x7) - $5.00 Each
130mm W x 50mm H
8. SUBARU STI BADGE PINK (x3) - $5.00 Each
100mm W x 50mm H
9. TOYOTA BADGE SILVER (x6) - $5.00 Each
84mm W x 55mm H
10. TOYOTA BADGE GOLD (x10) - $5.00 Each
84mm W x 55mm H
11. RALLIART BADGE (x7) - $5.00 Each
150mm W x 30mm H
12. TYPE R BADGE (x5) - $5.00 Each
130mm W x 30mm H
13. NISSAN BADGE SILVER (x3) - $5.00 Each
81mm W x 59mm H
14. NISSAN BADGE GOLD (X3) - $5.00 Each
81mm W x 59mm H
15. OPEL BADGE (x15) - $5.00 Each
80mm W x 60mm H
16. IMPREZA BADGE (x5) - $5.00 Each
120mm W x 20mm H
17. NISMO CURSIVE BADGE (x10) - $5.00 Each
150mm W x 40mm H
18. NOS BADGE (x5) - $5.00 Each
110W x 40mm H
19. TURBO BADGE (x6) - $5.00 Each
135mm W x 25mm H
20. NISMO BADGE SILVER (SILVER DOT) (x8) - $5.00 Each
160mm W x 25mm H
21. MUGEN BADGE (x1) - $5.00 Each
160mm W x 25mm H
22. SILVIA BADGE (x6) - $5.00 Each
45mm W x 70mm H
23. NO FEAR EYES BADGE RED (x5) - $5.00 Each
105mm W x 25mm H
24. NO FEAR EYES BADGE BLACK (x5) - $5.00 Each
105mm W x 25mm H
25. HONDA BADGE (x5) - $5.00 Each
78mm W x 65mm H
26. DUB BADGE (x5) - $5.00 Each
100mm W x 40mm H
27. STI BADGE PINK (x5) - $5.00 Each
110mm W x 40mm H
28. TOYOTA BADGE (x5) - $5.00 Each
149mm W x 27mm H
https://www.sau.com.au/forums/topic/305075-fs-car-badges-keyrings-acc-qld/
29. TRD FUEL FILLER CAP PLASTIC DECAL (x2) - $5.00Each
SILVER - ROUND
120mm Diam.
30. TRD FUEL FILLER CAP PLASTIC DECAL (x1) - $5.00 Each
BLUE - ROUND
120mm Diam.
31. TRD FUEL FILLER CAP PLASTIC DECAL (x1) - $5.00 Each
RED - ROUND
120mm Diam.
32. TRD FUEL FILLER CAP PLASTIC DECAL (x1) - $5.00 Each
YELLOW - ROUND
120mm Diam.
33. TRD FUEL FILLER CAP PLASTIC DECAL (x1) - $5.00 Each
YELLOW - ROUND
120mm Diam.
34. TRD FUEL FILLER CAP PLASTIC DECAL (x2) - $5.00 Each
BLUE - SQAURE
130mm W x 105mm H
35. TRD FUEL FILLER CAP PLASTIC DECAL (x1) - $5.00 Each
RED - SQAURE
130mm W x 105mm H
36. AUTOBOTS FUEL FILLER CAP PLASTIC DECAL (x3) - $5.00 Each
BLUE - SQAURE
150mm W x 125mm H
37. AUTOBOTS FUEL FILLER CAP PLASTIC DECAL (x3) - $5.00 Each
RED - SQAURE
150mm W x 125mm H
38. AUTOBOTS FUEL FILLER CAP PLASTIC DECAL (x1) - $5.00 Each
RED - CIRCLE
125mm Diam.
39. DECEPTICON FUEL FILLER CAP PLASTIC DECAL (x1) - $5.00 Each
RED - CIRCLE
125mm Diam.
40. DECEPTICON FUEL FILLER CAP PLASTIC DECAL (x2) - $5.00 Each
RED - SQAURE
150mm W x 125mm H
41. DECEPTICON FUEL FILLER CAP PLASTIC DECAL (x2) - $5.00 Each
BLUE - SQAURE
150mm W x 125mm H
42. NISMO METAL KEYRING (x8) - $10.00 Each OR 2 FOR $15.00
80mm W x 20mm H
43. TRD METAL KEYRING (x6) - $10.00 Each OR 2 FOR $15.00
80mm W x 15mm H
44. NISSAN LEATHER WALLET (x1) - $15.00 Each (ONLY 1 LEFT)
45. FORD BADGE (x4) - $5.00 Each
115mm W x 45mm H
46. SUBARU STI BADGE BLACK (x3) - $5.00 Each
100mm W x 50mm H
hey mate im after 1 Nismo cursive badge and 1 nismo keyring if you still got em im in adelaide.. sorry cant pm yet if you do can you pm me the payment details cheers.. :D
Edited by SLEEPA31
  • 3 weeks later...
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
