Yes the S13's don't have alot of room, but having a sunroof model makes it worse. There are low mount seat rails available that provide more headroom also.
I'm 6ft tall and have no problem but I imagine anyone over 6ft 2 would face difficulties.
yeah being 6'3" means that the cars i do fit in is sometimes limited.
shame about the track. i never went there but any time a track closes in Australia its a shame because new ones arent being built to replace the old ones.
  • Replies 63
  • 2 months later...
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
