Heyyyyy guys im all new to this, a week ago i have just brought an imported r34 skyline from victoria though it got approval over there when i took it to regency ( motor identification place ) they failed the check due to some parts tht i need to either replace or take off so i was really hoping if anyone from adelaide would be able to hlp me if they have standard parts if i could borrow them for a couple hours just to get it registered it would mean alot since im really stuck thank guys
the parts i need to change are:
i need standard tyres for an r34 as mine art the right sizes
i need standard suspension as mines automatic coil overs
and also a standard r34 exhuast as at the moment i have a hks exhaust on it
though i also got done for having a turbo timer and blow off valve i can just take those off
if anyones i little hesident on leding the parts i can leave a deposit in your hands jst until i get it registered or i can leave my parts with you :(
welcome to the forum Keith....have you tried contacting like an import wrecker like JIS....or an import yard???
sorry i dont have R34 stuff otherwise i would lend it to you mate.....as for your exhaust just get a baffle plate made up mate
Hi Keith, welcome to the site.
FYI there already is a thread of items that are 'wanted to borrow' and plenty of people have listed parts in there they are willing to lend.
http://www.skylinesaustralia.com/forums/Wa...ow-t220735.html
If you have a 4 door R34 I have a set of stock suspension you can hire.
PM Luke_ENR34, he has a stock 4 door exhaust, and last I knew had a set or R34 stockies.
But check the thread I listed above and start PMing. In my opinion a normal hire fee for these sort of things is $50 an item, but everyone has a different opinion - some free, some much more.
heyy mate thanks heaps umm do u no if the suspension on the 4 door wud b the same as on the two door?
what do u mean by baffle plate mate?
a piece of metal that goes in the exhaust to disrupt the flow of air - makes it quieter at the cost of airflow
-D
aaaak ;) na i gota replace the whole thing jst coz wen i got the car it had already been complied to aus standards but the guy i then brought the car frm put them bak on the car but i rkn iv found someone thatll lend me theres jst for a couple hours :) cheers anyway mate by any chance u wudnt no anyone tht has stock suspen do ya?
cheers
I am not sure if the 4 door suspension is the same as 2 door mate.
ill find out tmro morin :down:
cud i lend it off u if its the same mate?
also if anythn did u want anythn for lettn me lend it for a couple hours?
cheers hpz mate
strange that they did that at the vehicle id inspection... when i brough my 33 in from victoria it would have failed a proper regency inspection but they didnt seem to care at the id place...
Edited by GoAhead
well they didnt but they sussed the turbo timer then they told me bout making it 100% standard as the compliance says it it then to bring it bak for another id check jst so it matches so they wrote a list dwn of wat i gota do iv practiali got everythn except standrd suspension so if anyone can help with tht it wd b the biggest help anddd the 4 dr suspen is the same on the 2 :down:
hey Keith please back off on the abbreviated typing - this is not a mobile phone, and you are not texting. It makes it VERY hard to read what you are talking about and makes you look like a tool. Just saying ....
sorry mate
so do you still have the suspension? if so could i borrow it for a couple hours so i can go through an id inspection check?
Yeah you can borrow the suspension for the price of a carton of Coronas :down:
Good luck on only needing it for 2 hours though - will take more than an hour to change the suspension over each time.
It is just sitting in my garage, so you can have it for a week if you want. I am pretty sure the R34 coupe and 4 door is physically the same suspension.
Only thing I don't have are the pillow/camber tops, so you have to use the ones on your current suspension.
thanks heaps mate yeh thats all good could i get a contact number or something so i could give you a call to organise it all?
2 door and 4 door suspension is the same. I swaped 2 door suspension into my 4 door no dramas. At the end of the week ill have standard GTT rims and tyres to lend out as well as stock suspension. R34 stuff is hard to find sometimes!
hey guys im after some standard r34 tyres to borrow to get through regency with could anyone please help?
thankyou
there 2605 tyre i need all four
im not sure why your tyres arent the right size? 2605 isnt a tyre size, if it is on the standard rim its most likely a 225/45/17 , 225 being the width in mm, 45 being the size of the sidewall of the tyre in mm, and 17 being the size rim it fits in inches.
    • I sense an out of control build thread coming up lololol. That 450kW goal will end up being 600 to 700kW LOL.
    • Nice, thanks for sharing your progress....that's a pretty long list you are putting into it!
    • Decided to upgrade my pressurised plastic coolant expansion tank for a fancy pants alloy version The OEM versions can get brittle, even the new plastic one I got when I first got the car is a starting to show signs of "stress" I wasn't cheap, but it is basically unbreakable
    • Morning all, I have an RB25DET Neo that's in need of a rebuild. Will need new pistons etc due to detonation damage. Would anyone be able to recommend a shop in Southeast Queensland who I could bring my long motor to for a rebuild? Just want someone who knows RBs and whos built a bunch of them before. TLDR - recommended engine shops for RB rebuild.
    • Gday Thought it was about time I started a build thread! As expected this project has snowballed into a huge financial liability, but unless you’re strong willed and responsible, it’s not a surprise. Background -  My first turbo car was an R32 GTS-4, got my full license and then totalled my Au Falcon a week later, so while trying to sell my RMZ450 dirtbike to buy another car a bloke offered to swap the R32 which at the time I felt like I was ripped off but looking back and seeing prices of those now ($40kish) it was a good deal, I didn’t know enough about these cars to appreciate what I had so sold it before the RB20 blew up. Between here and there, out of 12 cars I’ve owned the note worthy ones are a V8 Lexus SC400 (soarer), a couple of XR6 Turbos and my beloved S15 which I had for about 3 years, picked it up for $12500, repairable write off but she was fine, gun metal grey/pewter and bone stock/unmolested until I got my hands on it. Ended up spending about the value of the car and 280kw, 2 demerit points by the time I got defected and sold it for $14500 (also $40kish in today’s market, rip) Fast forward to the present day, I’m in a much better position financially and daily an MQ Triton (great cars, pipe down Ranger Bois), I cruised marketplace and car sales for a few months looking for another R32, the best deal I could find was an absolute rust bucket half finished project for $12000, until this R33 popped up in Port Macquarie for $18k - unregistered and barely running but decent shape, kept an eye on it for a few weeks and the price steadily dropped, $16k then $15k then $14k, that was the point where I was like shit someone’s gonna snatch this up! It was owned by a young bloke who had big plans but him and his missus just had a baby so smartest move financially for them but big gain for me. So 2 days later I’m towing a car trailer to pick this thing up. Roughly 2 weeks and $3500 later I’m cruising around Newcastle in my beat up R33 all smiles and dose noises! It only needed some basic shit to get it going, coil packs and air flow meter, electrical stuff and all fluids changed, 158k kms and running pretty good, nice smooth engine after oil and coolant flush - when I say coolant I mean it had been filled up with tap water, every gallery and heater element was filled with rust, 8-9 flushes later and still had brown liquid coming out but she’ll be right. The car was painted R34 Bayside Blue at some point but whether it was a cheap job or just not looked after is anyone’s guess, clear coat flaking like sausage roll.  Was rethinking my choices and contemplating life, had it up for sale for $22k - still cheaper than any registered R33 but got little interest, next minute I had an opportunity at work - 6 months overseas for good money, so that was a no brainer, fast forward again and here we are with a 50% finished project. Current Mods - 200ish KW according to butt dyno Was tuned with Apexi PowerFC EBC (old school Greddy Profec)  Stock turbo (more shaft play than a Tinder date gone right) 3inch turbo back Varex muffler  Aftermarket injectors of mystery size, Power FC showed 36% duty cycle at full boost so not behd good size Someone had good intentions but stuck with the stock R33 MAF so we had misfires at 6000rpm due to the MAF hitting 5.2V So far I’ve redone the entire interior with carpet form Car Mats Direct, new Seats and steering wheel from Autotechnica, also sound system by Autobarn (mainly Kicker) Also MCA pro comfort coil overs - Hands down best purchase yet, worlds of improvement over the tired 30yrold shocks Goals - 450kw/600hp on flex tune New paint job - Midnight Purple 2 Engine is at the shop getting rebuilt with forged rods a pistons, new valves and springs, ATI Harmonic balancer, Aeroflow 7.5L sump, rear head drain and oil restrictors as per oil control thread* and cam covers modded for larger breathers, other stuff I can’t recall of the top of my head Parts purchased and to be installed once the engine is done -  Engine loom from Wiring Specialties including these options: Haltech Nexus S3 R35 Coil pack conversion  PRP Dual Trigger kit Fan controller  Other Parts -  262 Kelford Cams Turbo - Hypergear ATR43SS3-ProS with T51R mod (whistly boi) 6 boost manifold (high mount) 50mm Turbosmart Pro gate (plumbed back for legal reasons) HKS Super Turbo Exhaust with High Flow Cat Custom 3.5inch dump and front pipe 1500cc Bosch injectors  Fuel Pump walbro 525 Haltech MAP and IAT sensors Haltech Flex Sensor Fenix Radiator with dual thermo fans LS1 Alternator Kit Oil Filter Relocation from EFI solutions and Cooling pro oil cooler Many other things sitting in my garage waiting for that engine to come back. Progress pics to follow -
