  • Replies 90
I am interested in the diff you have for sale, I am a new to this site but would like to talk to you regarding payment & transporting of diff etc. My email address is [email protected] could you email your phone No please
r34 gtr powerfc with hand controller $950
r34 gtr vspec rear bar, bayside blue $350
r34 gtr carbon fiber lower lip (cracked, needs repair) $100
r34 gtr boot lid with tail light, silver colour (holes where wing has been removed) $100
r34 gtt Bride drivers side rail for Bride bucket seats (e.g. Zeta II, III, Guardis III) $200
Racepace 3.5" rear muffler, super high flow but quiet $650
r33 gtst rear brake rotors and calipers (painted red) $300
- r34 gtr powerfc with hand controller $950
- r34 gtt Bride drivers side rail for Bride bucket seats (e.g. Zeta II, III, Guardis III) $200
- r34 gtr boot lid silver colour (no wing) $100
- r33 gtst rear rotors and calipers $300
- s14a genuine ganador aero mirrors (painted pearl white) $400
- Racepace 3.5" rear muffler, super high flow but quiet (was used on my 360kw atw R34) $650
[email protected]
these items still available:
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
